How to Repair Corners of Drywall
crwdns2936025:03crwdne2936025:0 —
Unscrew screws in the section of bead that you are going to remove.
If it is a vinyl corner bead, then break taped underside with corner of putty knife carefully.
Cut the metal corner bead with tin snips.
If Vinyl, then use your utility knife.
Measure new corner bead and cut.
Place new corner bead on corner and fasten in place using screws or tape.
