iPhone 8 Plus LCD and Digitizer Replacement
crwdns2936025:02crwdne2936025:0 —
Use a Y000 driver to remove three 1.2 mm screws from one side of the display EMI shield.
If you have trouble loosening these screws, press the driver harder onto the screw as you turn it. If necessary, use the flat edge of your spudger to brace each display clip from behind so you can apply more pressure to the screws, without bending the clips.
