Zoom H6 Handy Recorder Motherboard Replacement
  1. Zoom H6 Handy Recorder Motherboard Replacement, Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Zoom H6 Handy Recorder Motherboard Replacement, Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Zoom H6 Handy Recorder Motherboard Replacement, Case: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place device face up and pry off the four knobs using the flat end of the plastic opening tool.
    • You may need to stabilize the device with the other hand.
  2. Zoom H6 Handy Recorder Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Zoom H6 Handy Recorder Motherboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Zoom H6 Handy Recorder Motherboard Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • With device facedown, lift the four rubber feet from the device using tweezers or fingernails.
  3. Zoom H6 Handy Recorder Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Zoom H6 Handy Recorder Motherboard Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With device still facedown, unscrew six (PH #1), 9mm screws; two located in center of back side of device right above the battery cover, and four under the rubber feet.
    • An electronics screwdriver small enough to fit in hole (4mm diameter), but long enough to reach the screws (at least 2cm) will be required to unscrew the screws.
  4. Zoom H6 Handy Recorder Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Zoom H6 Handy Recorder Motherboard Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Zoom H6 Handy Recorder Motherboard Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • With the bottom of the device on a table, lift the top of the device and gently place it aside.
    Does anyone know where to buy replacement parts?
    Kyle Scheffler - crwdns2934203:0crwdne2934203:0
    Hi I have questions where can I find sell for zoom H6 ?
    Ali Alsaleh - crwdns2934203:0crwdne2934203:0
    Me too. I have contact Zoom but no answer..
    Nacho -
  5. Zoom H6 Handy Recorder Motherboard Replacement, Motherboard: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Zoom H6 Handy Recorder Motherboard Replacement, Motherboard: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Zoom H6 Handy Recorder Motherboard Replacement, Motherboard: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew three (PH #1), 7mm screws from the display backing and gently flip over.
    The red highlight circle for the top screw in the first picture of step 5 is in the wrong place. The screw is actually on the right side, just slightly above the bottom left one. The top screw is shown still attached in the second and third picture of the series.
    brian - crwdns2934203:0crwdne2934203:0
    Olá como faço para comprar o display para esse gravador
    igorrabelo_locutor - crwdns2934203:0crwdne2934203:0
    Queimou o display do meu gravador h-6 vocês podem me ajudar
  6. Zoom H6 Handy Recorder Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Zoom H6 Handy Recorder Motherboard Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Zoom H6 Handy Recorder Motherboard Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a plastic opening tool, unlatch the clip and carefully unplug the ribbon connector from the device.
    • Set the button board aside.
  7. Zoom H6 Handy Recorder Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew four (PH #1), 8mm screws from the motherboard.
  8. Zoom H6 Handy Recorder Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect wire from motherboard using tweezers.
    • Do not touch the motherboard with metal tweezers. Only touch the plastic part of the plugged-in wire.
  9. Zoom H6 Handy Recorder Motherboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn device 180 degrees to unscrew two (PH #1), 8mm screws from the mic connector.
  10. Zoom H6 Handy Recorder Motherboard Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Zoom H6 Handy Recorder Motherboard Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Zoom H6 Handy Recorder Motherboard Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently remove three ribbon connectors from the device.
    • The first is connected to the mic connector.
    • The second is connected to the base of the device, and the third is connected to the power switch on the side of the device; turn the device 180 degrees, and the connectors are near the top of the device next to the "LINE OUT" plug-in (directly behind the device display).
    • It's best to use tweezers to remove the two ribbon connectors behind the display.
    • Avoid touching anything but the ribbon connectors with the metal tweezers.
  11. Zoom H6 Handy Recorder Motherboard Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Zoom H6 Handy Recorder Motherboard Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently lift the motherboard from the base of the device and set aside.
Cheryl Avery
crwdns2935283:002/14/18crwdne2935283:0
448 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S5-G2, Eyestone Spring 2018 crwdns2935289:0USF Tampa, Team S5-G2, Eyestone Spring 2018crwdne2935289:0
USFT-EYESTONE-S18S5G2
crwdns2947412:018crwdne2947412:0
Good night Mr.
I have a H6 recorder H.6 handy recorder, never use, but the battery stay in and it leak in the box.
When i remove the leaking battery, and i renew the battery the recorder did not start. According a technician the aparatus have to be open and chance the plate, but we does not have those technician on the island. please advice.
Edgar.
leito - crwdns2934203:0crwdne2934203:0
hello, i just have a question, where can i find this parts?
tahitibob57 - crwdns2934203:0crwdne2934203:0
Can i get Zoom H6 Handy Recorder Motherboard only i need it and the price
Adebanjo Sulaimon - crwdns2934203:0crwdne2934203:0
What was the problem? How do you diagnose a bad LCD screen? My screen goes white and nothing else comes on. So there is power, but nothing comes on the screen but the white background.
Caro - crwdns2934203:0crwdne2934203:0
I have the same issue with my H6. Do let me know the salutations if you got any... Thanks 🙏
peeaks.com@gmail.com
P K Sharma Peeaks -
For me, the recorder turns on, the screen is white and nothing else. Please tell me how to solve this problem. smincs@hotmail.com
Rashpil' Mc. -
The motherboard is no longer available on the above site https://shop.audiotronic.fr/en/61-h6
Any ideas on where to find it?
Alex Roth - crwdns2934203:0crwdne2934203:0
Hi Alex. Have you gotten a motherboard?
Tyra_th -
Hi, we have Zoom H6 recorder, mother needs replacement, can someone help in India. If there are any authorized centers for repairs in India, please guide. Thanks
Shishir Karnik - crwdns2934203:0crwdne2934203:0
Hello Shishir. Did you get a motherboard?
Tyra_th -
Congratulations for H6 !
What about Zoom F4 Recorder?!
You have any solutions for this device?!
Alexander Charalabidis - crwdns2934203:0crwdne2934203:0
Can I get the Zoom H6 Handy Recorder motherboard just that I need. I searched, but did not find it on the site. What is the part number?
Hope you email me: thepulsehot@gmail.com
YAHIA - crwdns2934203:0crwdne2934203:0
Hi. I looking for slot sd card. Please help :-)
Kermiczi - crwdns2934203:0crwdne2934203:0
How can I get the motherboard replacement for zoom H6n and how much will it cost me? +2348033706620 Whatsapp
MauriceKings - crwdns2934203:0crwdne2934203:0
Hey Maurice, I also need to change the motherboard. Could you get a replacement?
Tyra_th -
Hey! Thanks for this article.Can I get Zoom H6 Handy Recorder Motherboard only I need it and the price
Tyra_th - crwdns2934203:0crwdne2934203:0
Enter the shop audio pageI go to the shop audiotronic page, but it does not open.
crwdns2936753:07crwdne2936753:0 19
crwdns2936753:030crwdne2936753:0 116
crwdns2942667:0crwdne2942667:0 9,273
