Zojirushi Rice Cooker NP-HMH10 Internal Battery Replacement
  1. Zojirushi Rice Cooker NP-HMH10 Internal Battery Replacement, Internal Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Zojirushi Rice Cooker NP-HMH10 Internal Battery Replacement, Internal Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Zojirushi Rice Cooker NP-HMH10 Internal Battery Replacement, Internal Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the device over and remove the four screws on the base using the Phillips #0 screwdriver.
    I have the hex security screw. Where can I get that tool?
    Michael Hoy - crwdns2934203:0crwdne2934203:0
    My Zojirushi comes with the Hex security screw. Where can I get that tool?
    Hi, you can find these hex screwdrivers on any big online shopping website like amazon. Make sure you measure the screw size before your buying, the screw size may differ base on your product.
    Sirui Wu -
    Hi Michael, we don't sell individual Hex security screwdrivers but if you're interested in buying a toolkit, our Manta toolkit includes various Hex security bits and Hex security SAE bits. There is an assortment of 112 steel bits in total with 2 drivers included too. Thanks!
    Sarah Westberg -
    It might be relevant to mention that the battery has the solder tabs welded onto them, so you will need to have a new one with these pre-welded to keep things simple.
    registration - crwdns2934203:0crwdne2934203:0
    These instructions also work for the HB618, with a few slight modifications. I added comments where appropriate.
  2. Zojirushi Rice Cooker NP-HMH10 Internal Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Zojirushi Rice Cooker NP-HMH10 Internal Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Be aware, one of the four screws is a security Torx screw.
    • Using a Torx T9 screwdriver remove one screw from the bottom of the rice cooker.
  3. Zojirushi Rice Cooker NP-HMH10 Internal Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Zojirushi Rice Cooker NP-HMH10 Internal Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently lift the base from the device.
    • Be aware, DO NOT damage the cables that connect the base part and device.
    For the HBC18 you may want to disconnect the while clip connecting cables coming from the front, and going to the little board at the back. This allows complete removal of the bottom.
  4. Zojirushi Rice Cooker NP-HMH10 Internal Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Zojirushi Rice Cooker NP-HMH10 Internal Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Zojirushi Rice Cooker NP-HMH10 Internal Battery Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the five screws connecting the heatsink to the device.
  5. Zojirushi Rice Cooker NP-HMH10 Internal Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Zojirushi Rice Cooker NP-HMH10 Internal Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the screws that connect the thick black and orange cables to the heat sink.
    The heatsink cables do not exist for the HBC18, but undo the copper wiring from a little black tab in between the white housing and the pot coils.
  6. Zojirushi Rice Cooker NP-HMH10 Internal Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Zojirushi Rice Cooker NP-HMH10 Internal Battery Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently unplug the white-head pins with red and white cables on the other side.
    Pull up on the flat cable connectors on the upper circuit board and disconnect all connectors.
  7. Zojirushi Rice Cooker NP-HMH10 Internal Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Zojirushi Rice Cooker NP-HMH10 Internal Battery Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Now switch to the fan of the heatsink. Using a tweezer carefully lift the four clips around the fan.
    • Pull out the fan.
    For HBC18 pul out fan and moe to the left of the machine hang it down the front (still attached to lower circuit board).
  8. Zojirushi Rice Cooker NP-HMH10 Internal Battery Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Zojirushi Rice Cooker NP-HMH10 Internal Battery Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • After removing the fan now you can take out the whole heatsink and access the below part.
    • Be careful about the cables that are still connected to the heatsink.
    For HBC18 you want to disconnect all cables and untangle them first. Take a picture if you need to remember where everything goes. After that gently lift up the white plastic contraption that holds the upper circuit board etc. Rotate it out of the way.
  9. Zojirushi Rice Cooker NP-HMH10 Internal Battery Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Zojirushi Rice Cooker NP-HMH10 Internal Battery Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Zojirushi Rice Cooker NP-HMH10 Internal Battery Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Above the PCB (Printed Circuit Board) is an isolated-plate. Take it away and unscrew the PCB below it.
    • Now you can have the access to the battery.
    HBC18 does not have the cover plate. Just unscrew the two screws lift up the PCB, disconnect remaining connecters so you can work on the PCB separately. This PCB is otherwise identical to what is described here, so no more HBC18 specific instructions.
  10. Zojirushi Rice Cooker NP-HMH10 Internal Battery Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Zojirushi Rice Cooker NP-HMH10 Internal Battery Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Zojirushi Rice Cooker NP-HMH10 Internal Battery Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn the PCB to the other side. Find the soldering point of the battery as in the picture.
  11. Zojirushi Rice Cooker NP-HMH10 Internal Battery Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Zojirushi Rice Cooker NP-HMH10 Internal Battery Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Desolder the two tabs then unplug the old battery.
  12. Zojirushi Rice Cooker NP-HMH10 Internal Battery Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Zojirushi Rice Cooker NP-HMH10 Internal Battery Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Zojirushi Rice Cooker NP-HMH10 Internal Battery Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Take out the new battery. Install it onto the PCB and solder it.
    • When you install the battery, be sure to put the positive and negative tabs into the right hole.
  13. Zojirushi Rice Cooker NP-HMH10 Internal Battery Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After soldering, you can check your result by making sure the front screen is displayed properly.
    I changed the battery on a similar model (NP-HLH10), process is the same. But the front screen displayed a timing only after reconnecting most of the cable ! So don't be scared if there is noting just after soldering the new battery
    xtof - crwdns2934203:0crwdne2934203:0
  14. Zojirushi Rice Cooker NP-HMH10 Internal Battery Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To reassemble your device, follow these instructions in reverse order.
    • Set the device to the correct time and save the setting. If the time is displayed properly, then congrats, you have successfully completed the replacement of the rice cookers battery! Go to make a delicious rice bowl to reward yourself.
    Very instructive. Well done.
    Ruben Diaz - crwdns2934203:0crwdne2934203:0
    Completely POOR design to bury a battery replacement in such a difficult location!!!
    Shun Kwai Ng - crwdns2934203:0crwdne2934203:0
Sirui Wu
crwdns2935283:001/09/21crwdne2935283:0
325 crwdns2915208:0crwdne2915208:0
York University, Team S2-G29, O'Regan Winter 2021 crwdns2935289:0York University, Team S2-G29, O'Regan Winter 2021crwdne2935289:0
YORK-O'REGAN-W21S2G29
crwdns2947412:08crwdne2947412:0
Thank you! It’s a shame the machine was designed without easy servicing for the battery. Otherwise a great rice cooker!
Paul Sharpe - crwdns2934203:0crwdne2934203:0
Nice repair. Thanks for sharing.
It looks as if you could replace the battery without doing any soldering. Once you break the yellow plastic surrounding the battery, can't you simply slide the battery out of the metal holder and slide in a new one?
gordonhamachi - crwdns2934203:0crwdne2934203:0
That’s not a holder. It comes from Panasonic with the two leads welded on and the yellow wrap is just there to keep those welds from seeing mechanical stress during shipping of the device it’s soldered into. If you pry the battery out, it’ll just break those spot-welds and won’t hold a new battery. Bottom line: It’s not designed to be user serviceable. It’s a PCB-mounted, soldered-on battery type. Someone on youtube suggested replacing it with a coin cell holder for a different battery size, but to each their own. I’ll probably replace mine with a genuine part from Mouser or Digikey. It’d be nice to use the delay cooking function again without having to set the clock first each time. It definitely is annoying that they expect customers to go to a service center for this. We hardly even have any electronics component stores in the USA anymore.
Note- I have a different model and it has a different battery. Don’t assume these instructions will translate to a different model. But thank you is due to Sirui Wu for sharing these.
Ryan Lewis -
Good Morning, when you had the rice cooker apart did you happen to notice if there might be a 120v tap on the power supply? The rice cookers from japan are much less expensive but only come in 100v 50/60hz
Navy Retired - crwdns2934203:0crwdne2934203:0
Zojirushi is also having model for export that are sold in Japan. I bought mine there and bring it back to Europe
xtof -
I’m trying this on my NP-HBC 18. Thx for the steps.
Caroline Crilly - crwdns2934203:0crwdne2934203:0
I have this Zojirushi NP-NVC-10 Induction heating cooker. The clock on the panel is working but the clock cannot be adjusted using the up and down button and also the cooker is dead, not cooking at all. All the button controls do not respond. So, what is the problem with this cooker. I checked the power board and it had 120V ac going through; the power board is on the cooker base cover of the cooker. I would like to know what supplies the power to the microprocessor board? It is derived from the mains? I believe when you power the cooker up, the front panel of the cooker should show some sign of light but my is completely dark except the clock is working. I will this time open it up and dismantle it completely to see how the other parts of the cooker is powered up. do you have a schematic diagram for this cooker. I really need to know how the mains voltage is distributed throughout the cooker PCBs so that I can check the PCB when I power it up. By the way can I power the cooker up with all loose PCBs
Wai Kam Tang - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 12
crwdns2936753:07crwdne2936753:0 48
crwdns2936753:030crwdne2936753:0 201
crwdns2942667:0crwdne2942667:0 17,028
