This guide will show you how to replace the screen display on the device. You will need a plastic opening tool, tweezers, two opening picks, a Phillip s #00 screwdriver, and a heat gun to complete this guide.
Flip the phone over so that the back panel of the phone is facing up.
Wedge the plastic opening tool between the black outer panel and the silver side panel.
Push down on the plastic opening tool to separate the back panel from the rest of the phone.
Continue to do this around all sides of the phone until the back panel has popped all the way off.
Using your fingers, slide the SIM card all the way out of the phone.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Remove the yellow Kapton tape by using the tweezers to peel it up and away from the device.
Using the Phillips #00 screwdriver, remove the two 3.0 mm screws located near the top of the phone, next to the rear camera.
Remove the fingerprint sensor flex cable, using the plastic opening tool to lift it out.
Using the tweezers, peel back the yellow Kapton tape located on the right side of the phone.
Using the Phillips #00 screwdriver, remove the 15, 3.0 mm rear panel screws located around the perimeter of the phone.
Flip the phone over so that the screen is facing up.
Wedge the plastic opening tool between the screen and the rear panel.
Push up on the opening tool to separate the panel from the phone.
Continue to do this around the entire phone until the rear panel is no longer connected to the device.
Use the tweezers to peel off the yellow Kapton tape.
Use the plastic opening tool to remove the connectors on the motherboard.
Use tweezers to remove the antenna. The antenna comes up on the right side of the phone, by the battery, and is attached to the motherboard.
Using the #00 Phillips screwdriver, remove the 3.0 mm screw located on the right edge of the phone, above the battery.
Wedge the plastic opening tool underneath the motherboard which is located at the top of the phone.
Push down on the plastic opening tool, lifting the motherboard away from the phone.
Continue to do this around all sides of the motherboard until it is fully removed from the phone.
Use tweezers to peel off the tape at the bottom of the phone.
Wedge the plastic opening tool under the charging port board at the bottom of the phone.
Push down on the plastic opening tool so the board pulls away from the phone.
Continue to do this around the charging port board until it comes all the way off the phone.
Use a heat gun to heat the adhesive under the battery.
Heat the battery for 1 minute then check if it is pliable. If needed, heat in intervals of 10 seconds until the battery can be removed.
Use a nylon spudger to pry the battery from the phone.
Great instructions, however, if you - like me - just want to replace the battery: steps 10-15 are not necessary. After step 9, proceed to 16. Makes it a whole lot easier
Battery change worked, but now the screen is not working. Any ideas?
I accidentally ripped open the plastic on the grey side of the battery. Is it still okay to use?
After installing the new battery I got, my display wasn’t coming on. For me, I just didn’t seat the display connector (next to the top most antenna post). Disconnecting it and reseating it did the trick.
Also, you can run a thin plastic card (like a gift card) behind the battery to gradually work at the adhesive behind it. Just pop up a side with a spudger for clearance and shimmy the card back and forth to gradually remove the adhesive.
Disconnect the digital flex cable connector, located at the top left of the phone, using a pair of tweezers.
Using your fingers peel up the LCD flex cables. These cables are black and flat.
Peel the flex cables off where they are attached to the frame.
Insert a plastic opening tool between the screen and the rear case and separate it carefully, starting at the bottom.
Push the digitizer flex cable through the hole in the frame to separate the LCD from the phone.
crwdns2935229:013crwdne2935229:0
