ZTE Maven 2 Daughterboard Replacement
  1. ZTE Maven 2 Daughterboard Replacement, Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ZTE Maven 2 Daughterboard Replacement, Back Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ZTE Maven 2 Daughterboard Replacement, Back Cover: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pry off the back cover by inserting an opening tool into the small space on the bottom left between the phone's cover and body.
    • Work your way around the phone with an opening pick to loosen the rest of the back cover.
    • Remove the cover.
  2. ZTE Maven 2 Daughterboard Replacement, Battery: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Push in and then up on the bottom of the battery to free it from its compartment.
    • Pull the battery out.
  3. ZTE Maven 2 Daughterboard Replacement, MicroSD Card: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ZTE Maven 2 Daughterboard Replacement, MicroSD Card: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using your fingers or blunt tweezers, carefully pull the memory card out of the slot.
    • A SIM card is used to demonstrate the process for removing the MicroSD card in these images.
  4. ZTE Maven 2 Daughterboard Replacement, Midframe: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the twelve 3 mm screws with a Phillips #00 screwdriver.
  5. ZTE Maven 2 Daughterboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ZTE Maven 2 Daughterboard Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ZTE Maven 2 Daughterboard Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Wedge the opening tool between the front and side panel to create a gap.
    • Slide the opening pick around the device to detach the midframe.
  6. ZTE Maven 2 Daughterboard Replacement, Motherboard: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ZTE Maven 2 Daughterboard Replacement, Motherboard: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ZTE Maven 2 Daughterboard Replacement, Motherboard: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Peel the sticker off the battery compartment, as some of the motherboard components are hidden under it.
    • Remove the six 3 mm screws with a Phillips #00 screwdriver.
    • Using a pair of blunt tweezers, carefully remove the black wire that's attached to the gold plates on the left side of the device.
  7. ZTE Maven 2 Daughterboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ZTE Maven 2 Daughterboard Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the opening tool, carefully detach the ribbon cables connected to the motherboard.
  8. ZTE Maven 2 Daughterboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ZTE Maven 2 Daughterboard Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Work the opening pick around the edges of the motherboard to loosen it up.
    • The motherboard is glued down with adhesive. Pushing firmly with the pick will help to loosen the components and remove them.
    • Pull the motherboard out of the device.
  9. ZTE Maven 2 Daughterboard Replacement, Daughterboard: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the daughterboard containing the charging port.
Kristen Gismondi
crwdns2935283:011/12/14crwdne2935283:0
95 768 crwdns2915208:0crwdne2915208:0
crwdns2935297:0255crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021 559crwdne2935297:0
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 60
