This guide explains how to replace the Mid Frame in a ZTE Blade X Max in step-by-step format. Make sure your device is powered off and you have access to a clear workspace before you begin.
Use the iOpener or heating pad to heat around the edges of the phone to melt the adhesive.
Slide the Jimmy along the under backing and lightly push the plastic up.
Carefully remove the backing from the phone once the closures are released.
Remove the opaque yellow sticker that indicates where the fingerprint scanner is connected to the back of the device.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Remove the two 1mm Phillips #000 screws on the small panel that was underneath the sticker.
Use the tweezers to remove the panel.
Use the tweezers to pull at the base of the film to remove the fingerprint scanner.
Remove the SD and SIM cards by pulling out the card tray from the slot on the right side of the device.
Remove the sixteen 1mm Phillips #000 screws from the midframe of the phone.
Use the Jimmy to remove the midframe from the device.
