Xiaomi Redmi Note Battery Replacement
crwdns2942287:0crwdne2942287:0This guide will show you how to replace the battery in your phone if it is old, damaged, or losing its charge too quickly. The replacement process is simple and only requires three steps.
Insert the plastic opening tool between the charging port and the rear case.
Pry the end of the rear case up from the charging port.
Run the plastic opening tool along the seam on the side of the phone to remove the rear casing.
Locate the indentation at the bottom of the battery.
Place a finger in the indentation and lift up to remove the battery.
Geht das so einfach auch bei Redmi note 7 ???
Ich fürchte nein, sie ist als “nicht entfernbar" beschrieben.
VauWeh -
Wie sieht es beim Redmi Note 11 S aus?
