Use this guide to remove the battery from your Xiaomi Mi Pad.
Remove the micro SD card slot from the left side of the device using either the metal pin included with the device or a SIM card eject tool.
Use a plastic opening tool and/or opening pick to gently pry the back panel away from the device. Work your way around the device, slowly increasing the gap.
Remove the twelve 3.0 mm Phillips #000 screws on the upper cover of the device.
Remove the upper cover from the device.
Use a plastic opening tool to disconnect the three ribbon cable connectors.
Carefully pry around the perimeter of the battery with a plastic opening tool to loosen the adhesive securing the battery to the device.
If you disconnected all three connectors, the charging port ribbon cable may have a small amount of adhesive securing it to the battery. Gently pry the cable free of the battery and lift the battery up and out of the device.
crwdns2935229:019crwdne2935229:0
crwdns2947412:012crwdne2947412:0
Where to purchase the Mi Paf battery?
Please please make a video for it. I need it desperately.
It is not so easy when u have a deal with factory battery. I think guide tell us about replace battery not first time ;)
Can somebody tell about replacement charge jack on this device?
Where can I get brand new mi tablet battery in india?
Step 3: got 2 screws cover with orange Mi sticker. Don’t forget to unscrew them.
Step 6: got tape stick behind the battery, very sticky. Need remove gently and slowly.
Other work very well, thanks for the tutorial. Successfully replace my Mi Pad battery.
What sort is brand for light adhesive (glue)?
Need the female connector for battery. This soldered to board.
By accident was destroyed and want to change it…
How know the part number ? and can help.
Dino
My mipad not starting after battery replacement. Red light blinks 2 times and shows MI logo then turn off… but boots perfect with old battery. How do i resolve this issue?
