Xiaomi Mi Curved Gaming Monitor 34" Disassembly
  1. Xiaomi Mi Curved Gaming Monitor 34" Disassembly, Remove bottom screws: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xiaomi Mi Curved Gaming Monitor 34" Disassembly, Remove bottom screws: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lay the monitor down on a soft surface.
    • Remove the 6 philips size 1 screws along the bottom.
  2. Xiaomi Mi Curved Gaming Monitor 34" Disassembly, Remove front bezel: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xiaomi Mi Curved Gaming Monitor 34" Disassembly, Remove front bezel: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pry off the bezel by carefully pulling away from the screen and down.
  3. Xiaomi Mi Curved Gaming Monitor 34" Disassembly, Remove front LED light conduit: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xiaomi Mi Curved Gaming Monitor 34" Disassembly, Remove front LED light conduit: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Take out the small plastic status led light conductor, so you won't lose it later.
  4. Xiaomi Mi Curved Gaming Monitor 34" Disassembly, Remove back screws: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xiaomi Mi Curved Gaming Monitor 34" Disassembly, Remove back screws: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Take out the six philps size 2 screws on the back.
    • One is behind a warrenty sticker. Your warrenty will be void after removing this.
  5. Xiaomi Mi Curved Gaming Monitor 34" Disassembly, Remove back shell: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xiaomi Mi Curved Gaming Monitor 34" Disassembly, Remove back shell: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xiaomi Mi Curved Gaming Monitor 34" Disassembly, Remove back shell: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert your prying tool between the border piece and back shell. Pry the border outward, and slightly pull up on the back shell to disconnect the clips.
    • If you have a suction cup, that makes removing the top easier.
    Xiaomi 34 inch monitor. Cannot turn on OSD. all 4 menu buttons not working, black screen 3 seconds then going back
    يعقوب زياد - crwdns2934203:0crwdne2934203:0
  6. Xiaomi Mi Curved Gaming Monitor 34" Disassembly, Separate LCD and backlight layers: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xiaomi Mi Curved Gaming Monitor 34" Disassembly, Separate LCD and backlight layers: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xiaomi Mi Curved Gaming Monitor 34" Disassembly, Separate LCD and backlight layers: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Set the panel up straight.
    • Pull the border slightly out and push it forward to release the plastic clips all around the edge.
    • It's easiest to start at the bottom right or left. You may need the prying tool again for the corner clips.
    • Be careful not to separate the layers too far as they are still connected at the bottom with fragile ribbon cables.
    • You'll be able to peek inbetween the layers to blow out dust or insects that got stuck there.
    • As you can see I had to turn on the monitor in this state to see the dust, but obviously this is not recommended.
    Please, next time, take a photo of panel. So if the panel goes bad, it would be easier to identify which part I should use it.
    Fernando Martinez - crwdns2934203:0crwdne2934203:0
crwdns2935229:05crwdne2935229:0
Epskampie
crwdns2935283:001/16/21crwdne2935283:0
280 crwdns2915208:0crwdne2915208:0
crwdns2947412:09crwdne2947412:0
Is there a way to fix up this monitor cracked screen?
Thiago Silvestre - crwdns2934203:0crwdne2934203:0
I cracked screen as well and searching solution))
gugula12 -
Where can one get a replacement screen?
Oshosanya Michael - crwdns2934203:0crwdne2934203:0
Same question...is there any store that sells this part ?
cturiel -
Is there any link/store where I can buy the mi 34 inch gaming monitor spare replacement screen? I just broke my one upon 1 week of purchase.
Mehedi Hasan -
Hello everyone. After some research, I have read many unhappy reviews of msi customer support. The same with people trying to get replacement parts for these. Best option is buying a spare or repair screen with intact Led panel and swap it out.
Fin Omslag Van Knoblet Samways - crwdns2934203:0crwdne2934203:0
is warranty void if I remove the screws?
juan perez - crwdns2934203:0crwdne2934203:0
any of you have the main board to sell?
Andrés Fischer - crwdns2934203:0crwdne2934203:0
I also look for the mainboard.
Dror Friedman - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 34
crwdns2936753:030crwdne2936753:0 175
crwdns2942667:0crwdne2942667:0 9,260
