Xiaomi Air 12 Speaker Replacement
  1. Xiaomi Air 12 Speaker Replacement, Rear Casing: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Orient the computer so the Xiaomi logo is at the bottom of the device.
    Hello,
    I have a problem on my Mi air 12 , specifically with the lcd cable port on the mother board. I want to replace it but i can’t seem to find where to buy the parts.
    Pleas help me
    Kind regards
    L.
    lanusjeleus - crwdns2934203:0crwdne2934203:0
  2. Xiaomi Air 12 Speaker Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xiaomi Air 12 Speaker Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xiaomi Air 12 Speaker Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the plastic opening tool underneath the top-middle rubber covering and lift upwards to reveal the hidden screw.
  3. Xiaomi Air 12 Speaker Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xiaomi Air 12 Speaker Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the eight 3 mm screws using the Torx T5 driver by inserting the screwdriver into each screw and rotating counterclockwise.
  4. Xiaomi Air 12 Speaker Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xiaomi Air 12 Speaker Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xiaomi Air 12 Speaker Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the plastic opening tool into each side of the computer and push the tool downwards to pop open the back cover.
    • You will hear popping noises as you remove the cover.
  5. Xiaomi Air 12 Speaker Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xiaomi Air 12 Speaker Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the back of the laptop by gently lifting the casing upwards.
  6. Xiaomi Air 12 Speaker Replacement, Speaker: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xiaomi Air 12 Speaker Replacement, Speaker: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the white and black speaker wires from the black tabs by pulling upwards from the device.
  7. Xiaomi Air 12 Speaker Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xiaomi Air 12 Speaker Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently pull the speaker connector out from the connection point using your hand.
  8. Xiaomi Air 12 Speaker Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xiaomi Air 12 Speaker Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xiaomi Air 12 Speaker Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the left speaker module by pulling the panel up from the device.
    • Repeat the same process for the right speaker module.
    • Left and Right speaker modules are denoted by an "L" and "R" respectively.
    • There will be a slight adhesive underneath the module.
Hannah Kwan
crwdns2935283:004/18/18crwdne2935283:0
869 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S18-G4, Livingston Spring 2018 crwdns2935289:0Cal Poly, Team S18-G4, Livingston Spring 2018crwdne2935289:0
CPSU-LIVINGSTON-S18S18G4
crwdns2935297:028crwdne2935297:0
Thanks for the tutorial! But where can i buy replacement speakers? My right speaker is overdriving all the time now, giving me a lot of loud buzz noises.
Nicolai - crwdns2934203:0crwdne2934203:0
The same for me. I’d like to replace the speakers because one of them is “crackling/vibrating”, but i don’t know where to buy them…
Maniac 45 - crwdns2934203:0crwdne2934203:0
same problem, mine at >50% vibrating very bad
isman87 - crwdns2934203:0crwdne2934203:0
have you found them? i need those too
Giorgio Pianesi -
Hello, i love this laptop and its been my companion for almost 3 years think the audio input jack got grounded because i heard a creaking sound when i inserted a metallic headset jack, the device was charging when it happened. Now the audio output from the audio jack port is like a minus one or somewhat instrumental. Any suggestions what to do?
James Prae Liclican - crwdns2934203:0crwdne2934203:0
Left speaker not working so i need a replacement part. Wrote to xiaomi but no answer yet.
konrad baniel - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 19
crwdns2936753:030crwdne2936753:0 41
crwdns2942667:0crwdne2942667:0 1,335
