Xelio P1001A-BK Rear Camera Replacement
  1. Xelio P1001A-BK Rear Camera Replacement, Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xelio P1001A-BK Rear Camera Replacement, Back Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 3 mm retaining screws from the side of the tablet with a Phillips #0 screwdriver.
  2. Xelio P1001A-BK Rear Camera Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xelio P1001A-BK Rear Camera Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the plastic opening tool in between the shelf halves and lift the top shelf half to detach the securing tabs.
    • There are four securing tabs located on each long side.
    • Before fully separating the shell halves, observe if the speakers are separated from the shell half. If they are still in their sockets, gently pry them loose with the plastic opening tool.
  3. Xelio P1001A-BK Rear Camera Replacement, Rear Camera: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the ribbon connector, and make sure it is secure.
  4. Xelio P1001A-BK Rear Camera Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently use a plastic opening tool to pry the camera loose from its socket.
    • Avoid using metal tools to prevent damaging internal components.
  5. Xelio P1001A-BK Rear Camera Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Check that the camera lens is clean and free of any debris.
  6. Xelio P1001A-BK Rear Camera Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xelio P1001A-BK Rear Camera Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xelio P1001A-BK Rear Camera Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a plastic opening tool to gently lift the small locking flap on the ZIF (Zero Insertion Force) connector.
    • Do not pry up the entire connector, only the small locking flap.
    • Once the flap is unlocked, gently pull the ribbon cable straight out of the connector.
    • Carefully lift the camera out of the tablet.
  7. Xelio P1001A-BK Rear Camera Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    Microfiber Cleaning Cloths
    $3.99
    • With a microfiber lens cleaning cloth, clean the camera lens.
  8. Xelio P1001A-BK Rear Camera Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xelio P1001A-BK Rear Camera Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xelio P1001A-BK Rear Camera Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the ribbon cable straight into the ZIF connector.
    • Make sure the contacts are facing the correct direction and the cable is fully inserted.
    • Press the locking flap down to secure the cable in place.
    • The indentation on the securing tab should face up when reinstalled.
    • Place the camera into its socket.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Caleb
crwdns2935283:003/11/15crwdne2935283:0
Colorado Springs, Team 4-2, Panko Spring 2015 crwdns2935289:0Colorado Springs, Team 4-2, Panko Spring 2015crwdne2935289:0
UCCS-PANKO-S15S4G2
crwdns2942667:0crwdne2942667:0 254
