Xbox Series S Power Supply Replacement
  1. Xbox Series S Power Supply Replacement, Peel off the sticker coverings: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xbox Series S Power Supply Replacement, Peel off the sticker coverings: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xbox Series S Power Supply Replacement, Peel off the sticker coverings: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Before you start this guide, turn off the Xbox and unplug any cables from it.
    • Use tweezers to peel off the two white screw covers located on the bottom corners of the back panel.
    Where can I get a shell replacement?
    King DK - crwdns2934203:0crwdne2934203:0
  2. Xbox Series S Power Supply Replacement, Remove the back panel screws: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    Magnetic Project Mat
    $19.95
    • Use a T8 Torx driver to remove the two 10 mm-long screws securing the back panel to the bottom panel.
  3. Xbox Series S Power Supply Replacement, Remove the bottom panel: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xbox Series S Power Supply Replacement, Remove the bottom panel: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xbox Series S Power Supply Replacement, Remove the bottom panel: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the bottom panel horizontally toward the back of the console until it comes to a stop.
    • This slides the clips out of the slots on the plastic case.
    • Lift straight up and remove the bottom panel from the plastic case.
  4. Xbox Series S Power Supply Replacement, Remove the plastic case screws: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a T10 Torx driver to remove the seven 51 mm-long screws securing the chassis to the plastic case.
  5. Xbox Series S Power Supply Replacement, Remove the plastic case: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xbox Series S Power Supply Replacement, Remove the plastic case: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xbox Series S Power Supply Replacement, Remove the plastic case: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • With the bottom of the Xbox facing you, pull the two bottom-rear corners of the plastic case away from each other.
    • As you pull the corners apart, slide the back panel towards the bottom of the device. This releases the back panel from the plastic case.
    • The back panel should now settle on top of the clips on the back of the plastic case.
    • The back panel is permanently attached to the aluminum chassis.
    • Do not attempt to fully remove the chassis from the plastic case with this technique. You may risk breaking your case.
  6. Xbox Series S Power Supply Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xbox Series S Power Supply Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xbox Series S Power Supply Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the bottom-left corner away from the chassis while swinging the chassis away from the plastic case.
    • You may need to lift the chassis to free it from the clips on the bottom-front of the plastic case during this process.
    • Remove the plastic case from the chassis.
  7. Xbox Series S Power Supply Replacement, Remove the power supply screws: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a T10 Torx driver to remove the seven 11.3 mm-long screws securing the power supply to the chassis.
    Qualcuno sa dirmi come rimuovere una vite bloccata che non gira?
    Mauro Belsito - crwdns2934203:0crwdne2934203:0
  8. Xbox Series S Power Supply Replacement, Remove the upper chassis: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox Series S Power Supply Replacement, Remove the upper chassis: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the device over.
    • Lift the upper chassis straight up to remove it.
  9. Xbox Series S Power Supply Replacement, Remove the power supply: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xbox Series S Power Supply Replacement, Remove the power supply: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xbox Series S Power Supply Replacement, Remove the power supply: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the power supply straight up to disconnect it from the motherboard.
    • Remove the power supply.
    Can you please tell whether it is indispensable to use the power supply with exactly the same Revision, S/N and P/N or is the same model number, like 1920, 1921 enough to make it work? Thanks for showing the teardown.
    Ali Taimoor - crwdns2934203:0crwdne2934203:0
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
crwdns2935229:012crwdne2935229:0
Robert Boyd
crwdns2935283:002/01/21crwdne2935283:0
29,481 crwdns2915208:0crwdne2915208:0
crwdns2935297:094crwdne2935297:0
crwdns2947412:08crwdne2947412:0
What is the name of the blue paste on the power supply, and does it need to be replaced?
Luna - crwdns2934203:0crwdne2934203:0
I'd assume this is thermal putty used in lieu of thermal pads. Similar to thermal pads, there is usually no need to replace or reapply them unless their position doesn't line up with the components that need heat conduction—in this case the storage expansion module. Hope this helps!
Manuel Haeussermann -
I’m still getting the same results as soon as I load into a game the xbox turns off.
Leo Hernandez - crwdns2934203:0crwdne2934203:0
Looks like we both wasted 75 dollars on a Microsoft money laundering scheme designed to breakdown and not be capable of repair.
midickcrosoft -
Did you end up finding out what the issue is?
Foshizel -
Does this work, if my Xbox doesn't turn on due to a power surge?
Joshua Williams - crwdns2934203:0crwdne2934203:0
Hola amigo, esa fuente es 100% original no copia?? Soy técnico y nesecito una original ORIGINAL
Yair González - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 18
crwdns2936753:07crwdne2936753:0 112
crwdns2936753:030crwdne2936753:0 602
crwdns2942667:0crwdne2942667:0 22,886
