Xbox One X Fan Replacement
crwdns2936621:0crwdne2936621:0
  1. Xbox One X Fan Replacement, Remove the sticker: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox One X Fan Replacement, Remove the sticker: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use blunt tweezers to peel off the sticker covering the right-side screw on the back of the console.
    • Before starting this guide: Turn off the device. Then, unplug any cables from the console.
  2. Xbox One X Fan Replacement, Remove the external screws: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a T10 Torx screwdriver to remove the two 12.6 mm–long screws located on the back of the console.
  3. Xbox One X Fan Replacement, Slide the upper case horizontally: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox One X Fan Replacement, Slide the upper case horizontally: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Rotate the console 90 degrees.
    • Pull the front of the upper plastic case horizontally toward the front of the console until it comes to a stop. This slides the clips out of the slots on the upper plastic case.
  4. Xbox One X Fan Replacement, Lift the upper case off the lower case: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox One X Fan Replacement, Lift the upper case off the lower case: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Rotate the console 90 degrees so that the back is facing you.
    • Lift up the left side of the upper plastic case (as viewed from the back of the console), stopping when it won’t lift any further.
  5. Xbox One X Fan Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xbox One X Fan Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xbox One X Fan Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • While continuing to hold the left side of the upper plastic case, push up on the right side to move the right-side screw boss out of the way.
    • If pushing up on the case doesn't work, try moving it in different directions until it can swing open.
    • Swing the upper plastic case open to 75 degrees.
  6. Xbox One X Fan Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox One X Fan Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Push the upper plastic case down and away from the console to remove it completely.
    I found this step a little hard to complete. I flipped down the lock and then removed the screws. The ribbon came out much easier that way.
    metric - crwdns2934203:0crwdne2934203:0
  7. Xbox One X Fan Replacement, Disconnect the ribbon cable: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xbox One X Fan Replacement, Disconnect the ribbon cable: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xbox One X Fan Replacement, Disconnect the ribbon cable: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the pointed end of a spudger, an opening tool, or your fingernail to flip down the small, hinged locking flap on the ribbon cable ZIF connector on the front circuit board.
    How do I put in the ribbon connector?
    Tanner Gillispie - crwdns2934203:0crwdne2934203:0
  8. Xbox One X Fan Replacement, Disconnect the ribbon cable: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use blunt tweezers to pull the ribbon cable down out of the connector.
    What happens if I broke the connector to the ribbon cable ?
    Brandon LittleHawk - crwdns2934203:0crwdne2934203:0
    If you broke the cable, then one Wifi module would be broken.
    Alex Barblexi -
    Why we dont remove at first the 3 screws and lift the board a little bit, before removing the cable completely?
    Alex Barblexi - crwdns2934203:0crwdne2934203:0
    That's how I always do it. You can then easily pull it out. It also makes it easier to put it back in if you reattach the board afterwards.
    Rijk -
  9. Xbox One X Fan Replacement, Remove the front circuit board screws: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a T8 Torx screwdriver to remove the three 13.3 mm screws securing the front circuit board to the upper metal case.
    How crucial and important is this step? I ovwrlooked it when doing this. Will this mess it all up?
    Ozzy Hernandez - crwdns2934203:0crwdne2934203:0
  10. Xbox One X Fan Replacement, Remove the front circuit board: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox One X Fan Replacement, Remove the front circuit board: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the front circuit board straight out away from the upper metal case and set it aside.
    • Grip the board on either side of where it is plugged in to avoid bending and damaging it.
    During the reassembly process, I highly recommend that you reattach and lock the ribbon cable (steps 7 and 8) before you attach the circuit board. There is plenty of ribbon to work with, and once the circuit board is attached it is nearly impossible to get the ribbon flat and aligned and pushed up into the guide. Obviously be careful you don’t yank the ribbon as you maneuver the circuit board into place, but who’s not being careful while they are doing this?
    Tim Davis - crwdns2934203:0crwdne2934203:0
  11. Xbox One X Fan Replacement, Remove the upper metal case screws: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a T10 Torx screwdriver to remove the six 47.7 mm screws securing the upper metal case to the lower plastic case.
    • Use a T8 Torx screwdriver to remove the two 7.5 mm screws securing the press connector to the upper metal case.
    Must remove power supply screws as well
    Kwame Tsunami - crwdns2934203:0crwdne2934203:0
    Hi, this step only includes the screws needed to remove the lower metal case. Guides that require removing the power supply screws will have a step later on with instructions on which screws to remove.
    Kyle Smith -
    Why we dont't remove the hard drive screws in this step, please?
  12. Xbox One X Fan Replacement, Detach the press connector: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox One X Fan Replacement, Detach the press connector: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the flat end of a spudger underneath the press connector on the side opposite of the ribbon cable.
    • Use the spudger to lift the press connector up and away from the upper metal case.
    • Don't push the spudger all the way to the socket. Prying up the socket may damage it.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
    I need to know what it calls and I will purchase the one like press connector on the upper metal case.
    Erick Rivera - crwdns2934203:0crwdne2934203:0
  13. Xbox One X Fan Replacement, Remove the lower plastic case: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xbox One X Fan Replacement, Remove the lower plastic case: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xbox One X Fan Replacement, Remove the lower plastic case: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the console over.
    • Hold on to the lower plastic case because it is no longer attached to the metal case.
    • Lift the lower plastic case up from the metal case and set it aside.
    I had a hard time getting the bottom case back on by trying to slide it over the console. It was easier for me to place the case on the table and guide the hardware into it. There are four holes just above the disc drive that are tricky to line up if you try to slip the case back on.
    When reassembling, ensure that the press connector and the ribbon cable are hanging outside of the chassis so that you can reattach them. The ribbon cable in particular is easy to leave inside of the case where it may get bent and crushed as you reassemble it.
    A.Kulcsar - crwdns2934203:0crwdne2934203:0
  14. Xbox One X Fan Replacement, Remove the lower metal case screws: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two T10 Torx screws securing the lower metal case:
    • One 7.7 mm screw
    • One 11.4 mm screw
    bei mir waren beide Schrauben identisch konnte sie auch komplett versenken
    Evtl. fand vor mir schon ein Austausch statt
    André Schuler - crwdns2934203:0crwdne2934203:0
    English translation:
    In my case both screws were identical and I could also countersink them completely. An exchange may have already taken place before me
    Benjamin Alfaro -
  15. Xbox One X Fan Replacement, Remove the lower metal case: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the lower metal case up off the upper metal case and internal components.
    • The disc drive may lift up with the lower metal case. Hold it down during this step.
    • Set the lower metal case aside.
  16. Xbox One X Fan Replacement, Unscrew the power supply and fan: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The disc drive is only attached to the motherboard by two cable connectors. Hold the disc drive when flipping the console over to avoid damaging it.
    • Use a T10 Torx screwdriver to remove the following screws securing the power supply and fan to the upper metal case:
    • Two 11.4 mm screws
    • One 11.4 mm screw
    Die zwei orangen Schrauben müssen aus meiner Sicht nicht unbedingt gelöst werden. Hatte Probleme die zweite wieder reinzudrehen da sich der Anschluss verschoben hatte.
    Habe Ihn daher vor Rücksetzung des Schritt 22 wieder angeschraubt. Ich konnte alle Schritte zum Rückbau Problemlos ausführen. Empfehle diesen Weg
    Somewhat superfluous - all 5 screws are identical.
    Nico Snyman - crwdns2934203:0crwdne2934203:0
  17. Xbox One X Fan Replacement, Loosen the disc drive: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox One X Fan Replacement, Loosen the disc drive: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the disc drive up so that its metal tab is unhooked from the power supply.
    • The disc drive is plugged into the motherboard. Don’t bend the wires more than necessary to avoid damaging them.
    • Place the disc drive on the upper metal case so that it sits over the hard drive. You'll need enough space to unplug the power supply from the motherboard.
  18. Xbox One X Fan Replacement, Unstick the foam tape near the power supply: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xbox One X Fan Replacement, Unstick the foam tape near the power supply: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xbox One X Fan Replacement, Unstick the foam tape near the power supply: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the flat end of the spudger underneath the dark grey foam tape starting at the corner closest to the power supply and edge of the console.
    • Lift up the corner.
    • Slowly push the spudger through to the other side of the tape until you can see the flat end emerge.
    • Remove the spudger slowly. There are two grey cables underneath the foam tape. Try to avoid hitting them with the spudger so that you don't damage them.
  19. Xbox One X Fan Replacement, Move the power supply: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox One X Fan Replacement, Move the power supply: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the power supply directly upward to unplug it from the motherboard.
    • Move the disc drive further away from the power supply if you need more space.
  20. Xbox One X Fan Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox One X Fan Replacement: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the power supply so that the cables are at a 90 degree angle.
    • Avoid pulling or bending the cables more than necessary to prevent damage.
  21. Xbox One X Fan Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox One X Fan Replacement: crwdns2935265:021crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • While holding the power supply above the console, move the two grey cables out of the plastic hook on the fan case.
  22. Xbox One X Fan Replacement: crwdns2935265:022crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Set the power supply on the table.
  23. Xbox One X Fan Replacement, Unplug the fan from the motherboard: crwdns2935265:023crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox One X Fan Replacement, Unplug the fan from the motherboard: crwdns2935265:023crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unplug the bundled cable connector connecting the fan to the motherboard by pulling directly upward.
  24. Xbox One X Fan Replacement, Remove the fan: crwdns2935265:024crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox One X Fan Replacement, Remove the fan: crwdns2935265:024crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the fan case up to remove it from the console.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Xbox One X Answers community for help.
crwdns2935229:019crwdne2935229:0
Kyle Smith
crwdns2935283:002/01/21crwdne2935283:0
45 930 crwdns2915208:0crwdne2915208:0
crwdns2935297:0123crwdne2935297:0
Nice....danke....meine sah vom Rauchen aus wie Sau....Topp Erklärung....daaaanke
Nightstalker - crwdns2934203:0crwdne2934203:0
befürchte bei meiner series X wird's genau so sein.....😝
crwdns2936751:024crwdne2936751:0 19
crwdns2936753:07crwdne2936753:0 100
crwdns2936753:030crwdne2936753:0 576
crwdns2942667:0crwdne2942667:0 36,797
