Xbox One Elite Controller Series 2 Left Joystick Replacement
crwdns2937549:0crwdne2937549:0
@HectorNavarroMX
crwdns2935283:006/25/18crwdne2935283:0
4.269 crwdns2915208:0crwdne2915208:0
crwdns2935297:026crwdne2935297:0
crwdns2947412:010crwdne2947412:0
Does this work for the series 1 elite controller also?
Nicola - crwdns2934203:0crwdne2934203:0
Can we please get some insight to what the silver tape that is put over certain leads?
- What is the silver tape?
- What is the silver tape used for?
- Which leads are the silver tape covering?
- What happens if silver tape is not used?
Noah Adams - crwdns2934203:0crwdne2934203:0
It is called Kapton Tape. It is used to protect components from heat during the rework process. If you don't use it, there is a chance of damaging the components. Even though the damage may not be seen by the naked eye. Hope this helps!
Ken Stopczynski -
It is aluminum tape not kapton tape. It is covering a surface mount component mounted within the area of the pins you have to desolder to remove the analog stick. He is covering it up to protect it from the heat and also to keep it from desoldering and moving while replacing the analog stick.
Damon Rowan -
ma per caso accetti spedizioni, perché anche a me mi si è rotto così
Gabriel Pisciotta - crwdns2934203:0crwdne2934203:0
Amazing job filming this! Really appreciate the effort.
Arissona Negron - crwdns2934203:0crwdne2934203:0
What do we do it the joystick covers are stuck? I’ve tried finger tips, using the different sized thumb covers, to using Gerber pliers to try to remove these to get to the actual joystick box.
Logan Carns - crwdns2934203:0crwdne2934203:0
what’s the difference between this joystick for $14 then the one on Amazon that is two for $20?
Chris - crwdns2934203:0crwdne2934203:0
My left thumbstick just constantly "unscrews" itself. The top metal dome portion unscrews from the tip of the joystick. Is there a replacement for the metal dome?
Yelir - crwdns2934203:0crwdne2934203:0
Use a lot of heat to get these off. My 65W soldering iron wasn't nearly enough and I had to add hot air to remove the sticks. A 100W or greater iron is probably required.
jerry507 - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 50
crwdns2936753:07crwdne2936753:0 252
crwdns2936753:030crwdne2936753:0 985
crwdns2942667:0crwdne2942667:0 48,889
