Xbox One Elite Controller (Model 1698) Daughterboard Replacement
  1. Xbox One Elite Controller (Model 1698) Daughterboard Replacement, Show me the Screws!: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox One Elite Controller (Model 1698) Daughterboard Replacement, Show me the Screws!: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • You can remove the side panels with a pry tool.
    • You don't need to remove the rubber. The rubber on this controller was already bad.
  2. Xbox One Elite Controller (Model 1698) Daughterboard Replacement, Removing the back panel screws: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 5 Torx Security Bit (TR9) screws.
    all the T8 screws on my controller have a clear filling in them, WTF?!?!?
    Patrick Henry - crwdns2934203:0crwdne2934203:0
    all my T8 screws have a clear filling in them, WTF?!?!?!
    I've never seen that, I can't advise much other than scrapping it out with an xacto knife
    EasyAsABC123 - crwdns2934203:0crwdne2934203:0
    My screws have a tiny metal pin in the center. Looks like I need a TR8 bit, not a T8. This might be what you are mistaking for a clear filling.
    Steve McGinn - crwdns2934203:0crwdne2934203:0
    Thanks it might be TR8 i’ll update the guide
    While a TR8 will work, they’re actually TR9 screws on mine (Model 1698, X912908-004).
    Daniel - crwdns2934203:0crwdne2934203:0
    TORX TR8 worked form the ifixit kit
    KRISTIAN KALLAWAY - crwdns2934203:0crwdne2934203:0
    My anolog stick is lagging on my elite 1 controller. Can I remove a anolog module from a normal xbox 1 controller and then put into the elite 1 controller would it be compatible. I have all the soldering irons and stuff. It's only that I dont have any money and wanted to no if thay would work . Thanks guy appreciate your time kris
    kriswadd@hotmail.com - crwdns2934203:0crwdne2934203:0
  3. Xbox One Elite Controller (Model 1698) Daughterboard Replacement, Popping that back panel off: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xbox One Elite Controller (Model 1698) Daughterboard Replacement, Popping that back panel off: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xbox One Elite Controller (Model 1698) Daughterboard Replacement, Popping that back panel off: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pry the panel next to the 3.5mm port.
    • Be careful to not rip the ribbon shown in the next step.
  4. Xbox One Elite Controller (Model 1698) Daughterboard Replacement, Warning Carefully remove the ribbon: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox One Elite Controller (Model 1698) Daughterboard Replacement, Warning Carefully remove the ribbon: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Be careful to not rip the ribbon cable.
    • You can pop the connector up to remove the ribbon easily.
    • Ribbon Cable
    My connector did not look like this and popping it up broke it
    Amarokstar - crwdns2934203:0crwdne2934203:0
    please post a picture of the connector so we can update this, you also might have a newer revision of the motherboard
    Is there any way to replace that connector bar or maybe an alternative to keeping the contacts down on the ribbon if it’s broken?
    Joe - crwdns2934203:0crwdne2934203:0
    @joe you can try tape, or even hot glue (easy to remove with rubbing alcohol), that might hold it down. I wasn’t able to find the connector but i’m sure if you count the number of pins and measure it you’d be able to locate a replacement connector on something like mouser.
  5. Xbox One Elite Controller (Model 1698) Daughterboard Replacement, Screws on controller motherboard: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 2 Torx (T6) screws.
  6. Xbox One Elite Controller (Model 1698) Daughterboard Replacement, Desolder wires from motherboard: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox One Elite Controller (Model 1698) Daughterboard Replacement, Desolder wires from motherboard: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Desolder the 4 wires on each side, these control the vibrations and the RT LT.
    If you are just replacing the main power board there is no need to desolder at this point. The main power board can be removed with the controller board still in place.
    Malc Foy - crwdns2934203:0crwdne2934203:0
  7. Xbox One Elite Controller (Model 1698) Daughterboard Replacement, Remove the motherboard: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox One Elite Controller (Model 1698) Daughterboard Replacement, Remove the motherboard: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull up from the "top" side of the controller on the daughterboard.
    Hi,
    I would like to know if I could get from you a Motherboard . In case you don' t have it, where could I find one?
    Thank you
    Alejandro Expósito - crwdns2934203:0crwdne2934203:0
    Hi, I have 2 not working controllers (both 1698 and 1708). The 1708 broke the bumper switch, I manage to fix it but as always, postponed. So, can I either swap Xbox One Elite comtroller (1698) into Xbox One (1708) shell/housing or vice versa??
    Or can I mix both motherboard together so I can make one of them working?
    Fitifazrul Rahman - crwdns2934203:0crwdne2934203:0
    It might work…it might damage one of the boards but probably wouldn’t
    EasyAsABC123 -
    I would like to buy a motherboard, can you please stock some up?
    davi_t - crwdns2934203:0crwdne2934203:0
    I don’t work for ifixit, I don’t know if they see comments on a private made guide.
    EasyAsABC123 -
    I decided to toss all this stuff in the trash at this point as I am not going to spend +$50 on equipment and replacement parts to fix a $60 controller. But thanks for the educational manual all the same.
  8. Xbox One Elite Controller (Model 1698) Daughterboard Replacement, Remove the Home Button Cover: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xbox One Elite Controller (Model 1698) Daughterboard Replacement, Remove the Home Button Cover: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xbox One Elite Controller (Model 1698) Daughterboard Replacement, Remove the Home Button Cover: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Be Careful to not lose the sync button.
    • Pry the middle section up from the home button side.
    • This will also remove the LB and RB which is a single part.
  9. Xbox One Elite Controller (Model 1698) Daughterboard Replacement, Remove the controller daughterboard: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox One Elite Controller (Model 1698) Daughterboard Replacement, Remove the controller daughterboard: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the 6 Torx (T6) screws.
    On the 2nd picture: the D-pad dome switches are covered by a clear plastic film: is possible to remove it/reattach that plastic film? I believe there might be something stuck underneath the dome switches that’s interfering with the d-pad buttons working reliably/consistently. I know I could just replace the daughterboard, but I’m trying to avoid doing that if I can just clean it some how/find a way around it
    [deleted] - crwdns2934203:0crwdne2934203:0
    This is just tacom tape :), feel free to buy more and replace
    Hi anyone know of where to find that rubber thing that goes on lb/rb trigger?
    kostas kazlauskas - crwdns2934203:0crwdne2934203:0
    rubber thing? You mean the lb and rb part itself? or the home button section?
    EasyAsABC123 -
    The lb/rb white rubber behind the button supoort rubber i dont know how its called
    kostas kazlauskas -
EasyAsABC123
crwdns2935283:001/22/10crwdne2935283:0
2.449 crwdns2915208:0crwdne2915208:0
Hola que tal amigo disculpa es posible sustituir esa misma placa por una de un mando one ?
tay redd - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 80
crwdns2942667:0crwdne2942667:0 9,395
