Xbox Duke Controller 6-Pin Cable Replacement
  1. Xbox Duke Controller 6-Pin Cable Replacement, Face Plate: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xbox Duke Controller 6-Pin Cable Replacement, Face Plate: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xbox Duke Controller 6-Pin Cable Replacement, Face Plate: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the seven black 8 mm screws holding the two halves of the Duke together using a Phillips #1 screwdriver.
    • To reach the deeply set screws, use a longer screw driver or a 4.0 socket bit in addition to the PH1 bit.
  2. Xbox Duke Controller 6-Pin Cable Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xbox Duke Controller 6-Pin Cable Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xbox Duke Controller 6-Pin Cable Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two halves of the Duke, placing the top plate face-down so the buttons don't fall out.
  3. Xbox Duke Controller 6-Pin Cable Replacement, Potentiometer: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox Duke Controller 6-Pin Cable Replacement, Potentiometer: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the stick caps from the potentiometers.
  4. Xbox Duke Controller 6-Pin Cable Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox Duke Controller 6-Pin Cable Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the connectors attaching the rumble motors to the motherboard using a pair of tweezers.
    • Be gentle when slipping the tweezers underneath the flaps of the connectors; they are fragile and can snap.
  5. Xbox Duke Controller 6-Pin Cable Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox Duke Controller 6-Pin Cable Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a Phillips #1 screwdriver, remove the four yellow 8 mm screws holding the motherboard to the bottom half of the controller.
  6. Xbox Duke Controller 6-Pin Cable Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox Duke Controller 6-Pin Cable Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the motherboard from the bottom half of the controller.
  7. Xbox Duke Controller 6-Pin Cable Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xbox Duke Controller 6-Pin Cable Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xbox Duke Controller 6-Pin Cable Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Desolder the connector pins holding the left trigger assembly in place.
    • Remove the trigger assembly by pushing on the black connectors that hold them to the motherboard.
  8. Xbox Duke Controller 6-Pin Cable Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Desolder all of the connector pins holding the potentiometer in place.
    • Pull out the potentiometers and solder the new ones into place.
  9. Xbox Duke Controller 6-Pin Cable Replacement, 6-Pin Cable: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xbox Duke Controller 6-Pin Cable Replacement, 6-Pin Cable: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xbox Duke Controller 6-Pin Cable Replacement, 6-Pin Cable: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the cable from the memory card slot, sliding the black plastic holder out of the slot.
    • Remove the plastic piece from the cable.
  10. Xbox Duke Controller 6-Pin Cable Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox Duke Controller 6-Pin Cable Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the memory card slot by sliding it away from the motherboard.
  11. Xbox Duke Controller 6-Pin Cable Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox Duke Controller 6-Pin Cable Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Desolder the pins holding the cable in place, then pull the cable away from the motherboard.
    • Solder the new cable into the motherboard.
Anthony Casino
crwdns2935283:002/15/25crwdne2935283:0
546 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 1-1, Gulbrandsen Spring 2025 crwdns2935289:0UMass Dartmouth, Team 1-1, Gulbrandsen Spring 2025crwdne2935289:0
UMASSD-GULBRANDSEN-S25S1G1
crwdns2936751:024crwdne2936751:0 13
crwdns2936753:07crwdne2936753:0 22
crwdns2942667:0crwdne2942667:0 36
