Xbox 360 Wireless Controller Left Analog Stick Replacement
crwdns2942287:0crwdne2942287:0Straight forward replacement of the analog joystick on the controller. To much COD Black Ops can leave it feeling loose and can cause a drift. Toughest part of this repair was the disassembly of the controller since it requires a Torx T8h screwdriver. Make sure you have it before starting this repair.
crwdns2944105:0crwdne2944105:0
crwdns2935267:0crwdne2935267:0Tweezers$4.99
The left stick is the most common one to go bad.
Depress the battery release button on the top of the controller. Remove the battery holder from the controller.
Use tweezers or similar instrument, to peel the barcode sticker from the battery compartment.
Remove the seven 9.3 mm T8 Security Torx screws securing the rear case to the front case.
Insert a plastic opening tool between the front and rear cases along the left edge of the controller. Rotate the tool toward the front of the controller to pry the two cases apart.
Grasp the controller by the battery compartment and the headphone jack. Lift the battery compartment away from the headphone jack, separating the rear case from the front case and logic board.
Tilt the bottom case slightly toward the trigger buttons to slide it off the top case
Here is a view of the inside of the controller. Note the vibration motors having different counter weights.
Remove the connector from the left motor (controller is positioned upside down, left controller will be shown right etc.)
Remove the connector from the right motor
Both motors are disconnected. Notice position of the motors inside the case for re-assembly.
Remove logic board
Notice placement of rubber membranes on the front case for reassembly.
To remove the covers of the analogs sticks, simply pull them from the mounting pegs.
View of the left analog stick to be removed.
To remove the left analog stick, the left trigger button will have to be removed first. Desolder the three solder points. Use desoldering wick and some flux to remove the solder.
Left trigger points unsoldered.
There are 2 snaps holding the left trigger piece in place, remove those. It may take a bit of force, but simply push the snap over and down.
Be extremely careful when soldering. I recently took apart the “for Windows" wired version, and the fragility of the circuit board's connection pads, even the ones for the USB wiring, was astonishing.
When removing the left trigger, make sure that the points are unsolderd properly, gently pull the trigger downward.
Left trigger removed.
With the left trigger removed, simply turn the logic board over and find the 14 solder connections
Use a desoldering wick and some flux to remove the solder.
Ensure that no other components get either desoldered or otherwise heat damaged.
Here, all points have been desoldered.
Pull off the 3D analog stick gently to ensure that all solder connections are unsoldered.
Remove the analog stick
Put the new 3D analog stick in place. Make sure that it is seated flush against the board.
Apply some flux to the solder points and the leg of the analog stick.
Solder the connections in place.
All points soldered back in place. The liquid black debris is flux. This can be removed by cleaning the board with some isopropyl alcohol after the soldering.
Here is the board with the new sticks and the left trigger button resoldered.
crwdns2935229:045crwdne2935229:0
crwdns2947412:014crwdne2947412:0
My controller left stick is physically okew..but in gaming it is moving on downwards...
How can I fix this,I don't knew to do this repairing!:(
Nice work, excellenté!
I would like to note, you can unscrew the security screws with a 00 Flat head screwdriver. I just did it now and got all the screws out. Just gotta find the sweet spot, but it works.
Where do you purchase the actual 2-axis module that get resoldered to the board?
muy buen tutorial, ¿¿¿no te sabras los valores de los condensadores c5 y c71??? es que tube un incidente y los arranque los dos.
un saludo
David Martin I can probably find an old board and measure those for you, at least the capacitance. What happened to your caps?
David Martin Probablemente pueda encontrar un tablero viejo y medirlos para ti, al menos la capacidad. ¿Qué pasó con tus condensadores?
I tried doing this and I mistakenly did not research the process first. I did not have a desoldering wick, so I just tried melting the solder and removing it a little at a time with the iron. I was able to get the old joystick off, but the solder is not sticking to the board, so I'm having trouble attaching the new one. Did I break something on the board?
Jonathan DeMattia
you may have “peeled of the pads. We would need to see your work to give you more of an idea. You want to move this to “Answers” and in there add some pictures to your question.
My original X360 wireless controller just died while I was playing, I double checked the batteries, the connection is good, I tried the play and charge cable but its still dead, and the controller its just 1 year old…
After resoldering the Left analog stick it look a bit to the left and downwards on the testing software. Is there any way to calibrate the position of the analog stick. Physically it looks straight in the center.
The left joystick seems physically okay, but in game it is nonfunctional. Any clue what has happened and how to fix it?
After soldering the calibration tool would not show movements and while removing the soldering while on it showed up some behavior, could it be that the soldering is not touching the circuit? I tried multiple times to redo it but no luck in one of the sides
Here is one of the soldering attempts https://imgur.com/a/TGk0KD3
Hi
I know the date of this topic is very old but i try this method and my left analog stick is working fine but, right analog and my lt and rt button is not working. I can share you are picture and please help to fix my controller.
What does .Ove mean
Dariel Rebollar - crwdns2934203:0crwdne2934203:0
No idea :-) but it’s fixed
oldturkey03 -
