X-street Lamborghini Murcielago LP670-4 SV Wheel Replacement
  1. X-street Lamborghini Murcielago LP670-4 SV Wheel Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the two 2.5mm Phillips #00 screws from the middle of the car.
    • Unclip the two clips to remove the battery cover.
  2. X-street Lamborghini Murcielago LP670-4 SV Wheel Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug the battery by pushing on the clip.
  3. X-street Lamborghini Murcielago LP670-4 SV Wheel Replacement, Underbody: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the two 2.5mm Phillips #00 screws from each side
  4. X-street Lamborghini Murcielago LP670-4 SV Wheel Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the side skirt covers on each side of the car.
  5. X-street Lamborghini Murcielago LP670-4 SV Wheel Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 X-street Lamborghini Murcielago LP670-4 SV Wheel Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift up and remove the two side skirts.
  6. X-street Lamborghini Murcielago LP670-4 SV Wheel Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the two 2.5mm Phillips #00 screws from the front skirt of the car.
  7. X-street Lamborghini Murcielago LP670-4 SV Wheel Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the front part of the underbody and pull it out from the main underbody.
  8. X-street Lamborghini Murcielago LP670-4 SV Wheel Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 X-street Lamborghini Murcielago LP670-4 SV Wheel Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the remaining seven 9mm Phillips #00 screws from the underbody of the car.
    • The second image shows a closer view of the rear three screws
  9. X-street Lamborghini Murcielago LP670-4 SV Wheel Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 X-street Lamborghini Murcielago LP670-4 SV Wheel Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the main underbody from the shell of the car.
    • Lift up the body to expose the wiring and hardware underneath.
  10. X-street Lamborghini Murcielago LP670-4 SV Wheel Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the reflective sticker from the top of the body.
  11. X-street Lamborghini Murcielago LP670-4 SV Wheel Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug the wire connector.
  12. X-street Lamborghini Murcielago LP670-4 SV Wheel Replacement, Steering Column: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 X-street Lamborghini Murcielago LP670-4 SV Wheel Replacement, Steering Column: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 X-street Lamborghini Murcielago LP670-4 SV Wheel Replacement, Steering Column: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the three 2.5mm Phillips #00 screws from the white steering column.
    • After removing the three screws, the steering column will pop out of position because of the springs underneath. To reassemble, put the springs back together as shown in picture #3.
  13. X-street Lamborghini Murcielago LP670-4 SV Wheel Replacement, Wheel: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pull the steering column up and remove it along with the wheels
  14. X-street Lamborghini Murcielago LP670-4 SV Wheel Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the wheels away from the steering column.
    • Replace the wheel assembly.
Liam Martinez
crwdns2935283:004/01/15crwdne2935283:0
568 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 24-3, Lancaster Spring 2015 crwdns2935289:0Cal Poly, Team 24-3, Lancaster Spring 2015crwdne2935289:0
CPSU-LANCASTER-S15S24G3
crwdns2936753:030crwdne2936753:0 1
crwdns2942667:0crwdne2942667:0 566
