The wheels connect the car to the ground. Any fault in these could hinder the car performance and replacing them would serve to improve the car.
Unscrew the two 2.5mm Phillips #00 screws from the middle of the car.
Unclip the two clips to remove the battery cover.
Unplug the battery by pushing on the clip.
Unscrew the two 2.5mm Phillips #00 screws from each side
Remove the side skirt covers on each side of the car.
Lift up and remove the two side skirts.
Unscrew the two 2.5mm Phillips #00 screws from the front skirt of the car.
Lift the front part of the underbody and pull it out from the main underbody.
Unscrew the remaining seven 9mm Phillips #00 screws from the underbody of the car.
Lift the main underbody from the shell of the car.
Lift up the body to expose the wiring and hardware underneath.
Remove the reflective sticker from the top of the body.
Unscrew the three 2.5mm Phillips #00 screws from the white steering column.
Gently pull the steering column up and remove it along with the wheels
Pull the wheels away from the steering column.
Replace the wheel assembly.
se puede cambiar las llantas?
