Whirlpool Refrigerator Water Inlet Valve Replacement
  1. Whirlpool Refrigerator Water Inlet Valve Replacement, Safety precautions: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. Whirlpool Refrigerator Water Inlet Valve Replacement, Unfasten the rear panel: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Whirlpool Refrigerator Water Inlet Valve Replacement, Unfasten the rear panel: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Whirlpool Refrigerator Water Inlet Valve Replacement, Unfasten the rear panel: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the screw(s) securing the rear panel.
    • Loosen the screw securing the water hose enough for the rear panel to freely move.
  3. Whirlpool Refrigerator Water Inlet Valve Replacement, Remove the rear panel: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Whirlpool Refrigerator Water Inlet Valve Replacement, Remove the rear panel: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Whirlpool Refrigerator Water Inlet Valve Replacement, Remove the rear panel: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the rear panel off the chassis to remove it.
  4. Whirlpool Refrigerator Water Inlet Valve Replacement, Remove the clip: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Whirlpool Refrigerator Water Inlet Valve Replacement, Remove the clip: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use needle nose pliers, or your fingers, to remove the plastic clip on the inlet valve assembly.
  5. Whirlpool Refrigerator Water Inlet Valve Replacement, Disconnect the front water hose: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Whirlpool Refrigerator Water Inlet Valve Replacement, Disconnect the front water hose: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Whirlpool Refrigerator Water Inlet Valve Replacement, Disconnect the front water hose: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Push the plastic ring above the front water hose to release its clips.
    • As you push the ring, pull the water hose downward to disconnect it.
    • Repeat the disconnection procedure for the other water hose on the inlet valve assembly.
  6. Whirlpool Refrigerator Water Inlet Valve Replacement, Unfasten the inlet valve assembly: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screw(s) securing the inlet valve assembly.
  7. Whirlpool Refrigerator Water Inlet Valve Replacement, Reposition the inlet valve assembly: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Whirlpool Refrigerator Water Inlet Valve Replacement, Reposition the inlet valve assembly: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Whirlpool Refrigerator Water Inlet Valve Replacement, Reposition the inlet valve assembly: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the inlet valve assembly off its slot in the chassis and rest it on the floor.
  8. Whirlpool Refrigerator Water Inlet Valve Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Whirlpool Refrigerator Water Inlet Valve Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place a clean and dry rag under the inlet valve assembly before continuing.
  9. Whirlpool Refrigerator Water Inlet Valve Replacement, Remove the clip: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Whirlpool Refrigerator Water Inlet Valve Replacement, Remove the clip: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use needle nose pliers, or your hands, to pull the clip off the rear water hose.
  10. Whirlpool Refrigerator Water Inlet Valve Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Whirlpool Refrigerator Water Inlet Valve Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Whirlpool Refrigerator Water Inlet Valve Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Push the yellow plastic ring above the rear water hose to release its clips.
    • As you push the ring, pull the water hose away from the inlet valve assembly to disconnect it.
  11. Whirlpool Refrigerator Water Inlet Valve Replacement, Disconnect the assembly wire connector: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Whirlpool Refrigerator Water Inlet Valve Replacement, Disconnect the assembly wire connector: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Whirlpool Refrigerator Water Inlet Valve Replacement, Disconnect the assembly wire connector: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a flathead screwdriver, or a similar tool, to disconnect any wire connectors attached to the inlet valve assembly.
  12. Whirlpool Refrigerator Water Inlet Valve Replacement, Remove the inlet valve assembly: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the inlet valve assembly from the chassis.
  13. Whirlpool Refrigerator Water Inlet Valve Replacement, Meter the inlet valve assembly: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • If you own a multimeter, you can test your inlet valve assembly's resistance.
    • A range between 500–1.5 kΩ is acceptable.
Repair didn’t go as planned? Ask our Answers community for help.
nicO
crwdns2935283:004/14/15crwdne2935283:0
15.945 crwdns2915208:0crwdne2915208:0
crwdns2935297:089crwdne2935297:0
crwdns2936751:024crwdne2936751:0 15
crwdns2936753:07crwdne2936753:0 91
crwdns2936753:030crwdne2936753:0 461
crwdns2942667:0crwdne2942667:0 10,811
