Hello all, today we will repair a water damaged phone.
it's a simple cell phone and quite easy to repair.
enjoy
Remove back cover & battery.
Remove the front case by prying it open. You will hear clicks.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use a Torx screwdriver to remove the screen screws.
Use a spudger or tweezers to remove the connector of the LCD screen.
The PCB board had water damage, see this in picture 3.
To remove the corrosion, dab a cotton swab with a little distilled water on the corroded area, the corrosion will disappear.
How and where to use the cotton swabs.
crwdns2935229:017crwdne2935229:0
no use .it is not switching on . replaced with good batter also. no on
try to clean with an ultrasonic bath.
measure out powerrail.
measure out the voltage coming in on board. try to see if you have short.
Nokia 206 display and charger pin
Not working kiy 1.2.3 and colling ricev kiy not working
