Wacom Intuos CTL4100 Battery Replacement
Marcus Sisouphanh
crwdns2944107:0crwdnd2944107:0Marcus Sisouphanhcrwdnd2944107:0crwdnd2944107:0crwdnd2944107:02crwdnd2944107:0crwdne2944107:0
crwdns2944111:0February 14, 2023crwdne2944111:0
15 - 30 crwdns2931279:0crwdne2931279:0
crwdns2937801:0crwdne2937801:0
crwdns2862591:0crwdne2862591:0
crwdns2942287:0crwdne2942287:0
Battery capacities degrade over time, reducing battery life. If the battery is not charging or the battery lifespan is not as long as it used to be, you might need to replace your battery. This guide will show you how to replace the battery of your Wacom Intuos CTL4100.
If your battery is swollen take appropriate precautions. Be sure to power off your device and unplug from any external power prior to beginning the repair.
crwdns2944105:0crwdne2944105:0
  1. Wacom Intuos CTL4100 Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Wacom Intuos CTL4100 Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Wacom Intuos CTL4100 Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the tablet over so the bottom case faces upwards.
    • Remove the rubber pads on the corners by pulling them up with your fingers.
  2. Wacom Intuos CTL4100 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Wacom Intuos CTL4100 Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Wacom Intuos CTL4100 Battery Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
  3. Wacom Intuos CTL4100 Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Wacom Intuos CTL4100 Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Wacom Intuos CTL4100 Battery Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a plastic opening pick between the front and back case to unclip the clips that hold the cases together.
    • Slide your plastic opening pick around the sides until all clips are unclipped.
  4. Wacom Intuos CTL4100 Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Wacom Intuos CTL4100 Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the bottom case to separate the top and bottom case
    • When you see the internal components, set aside the bottom case.
  5. Wacom Intuos CTL4100 Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Wacom Intuos CTL4100 Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the yellow tape that is on top of the battery wires.
    • When the battery wires under the tape are exposed, stick the yellow tape just above the battery wires.
  6. Wacom Intuos CTL4100 Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Wacom Intuos CTL4100 Battery Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently pull up the battery wire pin with your fingers to disconnect the pin from the motherboard.
  7. Wacom Intuos CTL4100 Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Wacom Intuos CTL4100 Battery Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the battery by lifting the battery up with your fingers.
  8. Wacom Intuos CTL4100 Battery Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the new battery on the area you removed the battery.
  9. Wacom Intuos CTL4100 Battery Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Wacom Intuos CTL4100 Battery Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently connect the battery wire pin to the motherboard.
  10. Wacom Intuos CTL4100 Battery Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Wacom Intuos CTL4100 Battery Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Reapply the tape you put above the battery wires.
To reassemble your device, follow step 4 in reverse order.
crwdns2935229:05crwdne2935229:0
Marcus Sisouphanh
crwdns2935283:009/11/21crwdne2935283:0
316 crwdns2915208:0crwdne2915208:0
York University, Team 1-24, O'Regan Fall 2021 crwdns2935289:0York University, Team 1-24, O'Regan Fall 2021crwdne2935289:0
YORK-O'REGAN-F21S1G24
crwdns2947412:05crwdne2947412:0
Where did you get the replacement battery?
David VeLar - crwdns2934203:0crwdne2934203:0
Will it work without a battery?
Jordi Prats - crwdns2934203:0crwdne2934203:0
Answering my own question, yes, it works without a battery. It will popup a notification of low battery sometimes, and obviously it won't work wirelessly.
Ah, and I tried this with a CTL6100 tablet, so this guide is valid for this model as well (a bit larger but mostly identical inside).
Jordi Prats -
Where did you get the battery pls?
Taaa - crwdns2934203:0crwdne2934203:0
I can probably say Aliexpress would be your best bet.
Gabriel Smirnov -
crwdns2936753:07crwdne2936753:0 21
crwdns2936753:030crwdne2936753:0 141
crwdns2942667:0crwdne2942667:0 4,754
