WRS315SDHW Water Filter Housing Replacement
  1. WRS315SDHW Water Filter Housing Replacement, Safety precautions: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. WRS315SDHW Water Filter Housing Replacement, Open the doors: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 WRS315SDHW Water Filter Housing Replacement, Open the doors: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 WRS315SDHW Water Filter Housing Replacement, Open the doors: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Depending on your repair, open one or both doors.
  3. WRS315SDHW Water Filter Housing Replacement, Unfasten the front panel: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 WRS315SDHW Water Filter Housing Replacement, Unfasten the front panel: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 WRS315SDHW Water Filter Housing Replacement, Unfasten the front panel: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips driver to remove the two 15.2 mm-long screws securing the front panel.
  4. WRS315SDHW Water Filter Housing Replacement, Remove the front panel: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 WRS315SDHW Water Filter Housing Replacement, Remove the front panel: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 WRS315SDHW Water Filter Housing Replacement, Remove the front panel: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the front panel straight off the chassis and remove it.
    • You may have to slightly open the water filter door to remove the front panel completely.
  5. WRS315SDHW Water Filter Housing Replacement, Unfasten the water filter housing: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 1/4 inch socket wrench to remove the two 18.9 mm-long screws securing the water filter housing.
    • Use a 1/4 inch socket wrench, or a flathead screwdriver, to remove the 15.6 mm-long screw securing the wire harness grounding wire.
  6. WRS315SDHW Water Filter Housing Replacement, Reposition the housing: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 WRS315SDHW Water Filter Housing Replacement, Reposition the housing: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the housing out of the chassis enough to access its left-hand water connections.
  7. WRS315SDHW Water Filter Housing Replacement, Remove the clips: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 WRS315SDHW Water Filter Housing Replacement, Remove the clips: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 WRS315SDHW Water Filter Housing Replacement, Remove the clips: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place a clean and dry rag under the water hoses.
    • Use needle nose pliers, or your fingers, to remove the blue clip on the bottom water hose.
    • Repeat for the red clip on the top water hose.
  8. WRS315SDHW Water Filter Housing Replacement, Disconnect the water hoses: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Compress the plastic ring near the end of the water hose.
    • While compressing the ring, pull the hose away from the ring to disconnect it.
    • Repeat for the other water hose.
  9. WRS315SDHW Water Filter Housing Replacement, Remove the housing: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the water filter housing.
Repair didn’t go as planned? Ask our Answers community for help.
nicO
crwdns2935283:004/14/15crwdne2935283:0
15,927 crwdns2915208:0crwdne2915208:0
crwdns2935297:089crwdne2935297:0
crwdns2942667:0crwdne2942667:0 171
