WRS315SDHW Inlet Valve Assembly Replacement
  1. WRS315SDHW Inlet Valve Assembly Replacement, Safety precautions: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. WRS315SDHW Inlet Valve Assembly Replacement, Unfasten the rear panel: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 WRS315SDHW Inlet Valve Assembly Replacement, Unfasten the rear panel: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 WRS315SDHW Inlet Valve Assembly Replacement, Unfasten the rear panel: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a 1/4 inch socket wrench, or a flathead screwdriver, to remove the seven 16.2 mm-long screws securing the rear panel.
    • Use a 1/4 inch socket wrench to loosen the screw securing the water hose enough for the rear panel to freely move.
  3. WRS315SDHW Inlet Valve Assembly Replacement, Remove the rear panel: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 WRS315SDHW Inlet Valve Assembly Replacement, Remove the rear panel: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 WRS315SDHW Inlet Valve Assembly Replacement, Remove the rear panel: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the rear panel off the chassis to remove it.
  4. WRS315SDHW Inlet Valve Assembly Replacement, Remove the clip: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 WRS315SDHW Inlet Valve Assembly Replacement, Remove the clip: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use needle nose pliers, or your fingers, to remove the plastic clip on the inlet valve assembly.
  5. WRS315SDHW Inlet Valve Assembly Replacement, Disconnect the front water hose: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 WRS315SDHW Inlet Valve Assembly Replacement, Disconnect the front water hose: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 WRS315SDHW Inlet Valve Assembly Replacement, Disconnect the front water hose: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Push the plastic ring above the front water hose to release its clips.
    • As you push the ring, pull the water hose downward to disconnect it.
    • Repeat the disconnection procedure for the other water hose on the inlet valve assembly.
  6. WRS315SDHW Inlet Valve Assembly Replacement, Unfasten the inlet valve assembly: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 1/4 inch socket wrench to remove the two 15.6 mm-long screws securing the inlet valve assembly.
  7. WRS315SDHW Inlet Valve Assembly Replacement, Reposition the inlet valve assembly: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 WRS315SDHW Inlet Valve Assembly Replacement, Reposition the inlet valve assembly: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 WRS315SDHW Inlet Valve Assembly Replacement, Reposition the inlet valve assembly: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the inlet valve assembly off its slot in the chassis and rest it on the floor.
  8. WRS315SDHW Inlet Valve Assembly Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 WRS315SDHW Inlet Valve Assembly Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place a clean and dry rag under the inlet valve assembly before continuing.
  9. WRS315SDHW Inlet Valve Assembly Replacement, Remove the clip: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 WRS315SDHW Inlet Valve Assembly Replacement, Remove the clip: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use needle nose pliers, or your hands, to pull the blue clip off the rear water hose.
  10. WRS315SDHW Inlet Valve Assembly Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 WRS315SDHW Inlet Valve Assembly Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 WRS315SDHW Inlet Valve Assembly Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Push the yellow plastic ring above the rear water hose to release its clips.
    • As you push the ring, pull the water hose away from the inlet valve assembly to disconnect it.
  11. WRS315SDHW Inlet Valve Assembly Replacement, Disconnect the assembly wire connector: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 WRS315SDHW Inlet Valve Assembly Replacement, Disconnect the assembly wire connector: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 WRS315SDHW Inlet Valve Assembly Replacement, Disconnect the assembly wire connector: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a flathead screwdriver, or a similar tool, to disconnect the inlet valve assembly wire connector.
  12. WRS315SDHW Inlet Valve Assembly Replacement, Remove the inlet valve assembly: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the inlet valve assembly from the chassis.
Repair didn’t go as planned? Ask our Answers community for help.
nicO
crwdns2935283:004/14/15crwdne2935283:0
15,927 crwdns2915208:0crwdne2915208:0
crwdns2935297:089crwdne2935297:0
crwdns2942667:0crwdne2942667:0 222
