WRS315SDHW Freezer Door Replacement
  1. WRS315SDHW Freezer Door Replacement, Safety precautions: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. WRS315SDHW Freezer Door Replacement, Open the doors: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 WRS315SDHW Freezer Door Replacement, Open the doors: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 WRS315SDHW Freezer Door Replacement, Open the doors: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Depending on your repair, open one or both doors.
  3. WRS315SDHW Freezer Door Replacement, Unfasten the front panel: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 WRS315SDHW Freezer Door Replacement, Unfasten the front panel: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 WRS315SDHW Freezer Door Replacement, Unfasten the front panel: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips driver to remove the two 15.2 mm-long screws securing the front panel.
  4. WRS315SDHW Freezer Door Replacement, Remove the front panel: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 WRS315SDHW Freezer Door Replacement, Remove the front panel: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 WRS315SDHW Freezer Door Replacement, Remove the front panel: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the front panel straight off the chassis and remove it.
    • You may have to slightly open the water filter door to remove the front panel completely.
  5. WRS315SDHW Freezer Door Replacement, Unfasten the door connections: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 WRS315SDHW Freezer Door Replacement, Unfasten the door connections: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a 1/4 inch socket wrench to remove the 16.7 mm-long screw securing the freezer door wiring harness.
    • Use a 1/4 inch socket wrench to remove the 16.2 mm-long screw securing the freezer door water hose.
  6. WRS315SDHW Freezer Door Replacement, Reposition the wiring harness: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 WRS315SDHW Freezer Door Replacement, Reposition the wiring harness: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the wiring harness out of its slot in the chassis to access its connectors.
  7. WRS315SDHW Freezer Door Replacement, Disconnect the wiring harness: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 WRS315SDHW Freezer Door Replacement, Disconnect the wiring harness: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 WRS315SDHW Freezer Door Replacement, Disconnect the wiring harness: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the two connectors attached to the door wiring harness.
  8. WRS315SDHW Freezer Door Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place a clean cloth under the water hose before continuing.
  9. WRS315SDHW Freezer Door Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 WRS315SDHW Freezer Door Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the plastic clip off the freezer door water hose.
  10. WRS315SDHW Freezer Door Replacement, Disconnect the water hose: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 WRS315SDHW Freezer Door Replacement, Disconnect the water hose: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 WRS315SDHW Freezer Door Replacement, Disconnect the water hose: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use one hand to compress the blue plastic ring into the green section of the hose.
    • Use the other hand to pull the white water tube out of its slot.
  11. WRS315SDHW Freezer Door Replacement, Unfasten the freezer door: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 WRS315SDHW Freezer Door Replacement, Unfasten the freezer door: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Hold the door while performing the next two steps to avoid the door from accidentally falling.
    • Use a 3/16 inch Allen wrench to remove the two 19.3 mm-long screws securing the freezer door.
    • The Torx screws are for alignment and don't need to be removed.
  12. WRS315SDHW Freezer Door Replacement, Remove the door hinge: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 WRS315SDHW Freezer Door Replacement, Remove the door hinge: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 WRS315SDHW Freezer Door Replacement, Remove the door hinge: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the door hinge straight up to separate its alignment pins from the chassis.
    • Remove the door hinge.
  13. WRS315SDHW Freezer Door Replacement, Reposition the cables: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 WRS315SDHW Freezer Door Replacement, Reposition the cables: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 WRS315SDHW Freezer Door Replacement, Reposition the cables: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the freezer door straight up to disconnect it from the chassis.
    • Thread the cables through their slot in the chassis.
    • You may need to thread them individually.
  14. WRS315SDHW Freezer Door Replacement, Remove the door: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 WRS315SDHW Freezer Door Replacement, Remove the door: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • You're now left with the freezer door.
Repair didn’t go as planned? Ask our Answers community for help.
nicO
crwdns2935283:004/14/15crwdne2935283:0
15,927 crwdns2915208:0crwdne2915208:0
crwdns2935297:089crwdne2935297:0
crwdns2942667:0crwdne2942667:0 132
