WRS315SDHW Evaporator Fan Replacement
  1. WRS315SDHW Evaporator Fan Replacement, Safety precautions: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. WRS315SDHW Evaporator Fan Replacement, Open the doors: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 WRS315SDHW Evaporator Fan Replacement, Open the doors: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 WRS315SDHW Evaporator Fan Replacement, Open the doors: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Depending on your repair, open one or both doors.
  3. WRS315SDHW Evaporator Fan Replacement, Remove the drawers: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 WRS315SDHW Evaporator Fan Replacement, Remove the drawers: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the drawers and shelves from the freezer section.
  4. WRS315SDHW Evaporator Fan Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 WRS315SDHW Evaporator Fan Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the screw(s) securing the evaporator cover.
  5. WRS315SDHW Evaporator Fan Replacement, Unclip the evaporator cover: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 WRS315SDHW Evaporator Fan Replacement, Unclip the evaporator cover: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 WRS315SDHW Evaporator Fan Replacement, Unclip the evaporator cover: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the bottom of the evaporator cover up and over its lip in the chassis.
    • Pull the cover toward yourself to release its top clips.
  6. WRS315SDHW Evaporator Fan Replacement, Remove the evaporator cover: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 WRS315SDHW Evaporator Fan Replacement, Remove the evaporator cover: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 WRS315SDHW Evaporator Fan Replacement, Remove the evaporator cover: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Continue pulling the evaporator cover towards yourself to unclip its metal prongs from the chassis.
    • Remove the evaporator cover.
  7. WRS315SDHW Evaporator Fan Replacement, Disconnect the evaporator fan: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 WRS315SDHW Evaporator Fan Replacement, Disconnect the evaporator fan: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use needle nose pliers, or your fingers, to disconnect the grounding wire attached to the evaporator fan.
  8. WRS315SDHW Evaporator Fan Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 WRS315SDHW Evaporator Fan Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 WRS315SDHW Evaporator Fan Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the connector attached to the evaporator fan.
  9. WRS315SDHW Evaporator Fan Replacement, Unfasten the evaporator fan: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 1/4 inch socket wrench to remove the two 13 mm-long screws securing the evaporator fan.
  10. WRS315SDHW Evaporator Fan Replacement, Remove the foam buffers: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 WRS315SDHW Evaporator Fan Replacement, Remove the foam buffers: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 WRS315SDHW Evaporator Fan Replacement, Remove the foam buffers: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the foam buffer downward to release it from its lip in the chassis.
    • Remove the foam buffer.
    • Repeat this procedure for the second foam buffer.
  11. WRS315SDHW Evaporator Fan Replacement, Remove the evaporator fan housing: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 WRS315SDHW Evaporator Fan Replacement, Remove the evaporator fan housing: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 WRS315SDHW Evaporator Fan Replacement, Remove the evaporator fan housing: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the evaporator fan housing up and outward from the chassis to remove it.
  12. WRS315SDHW Evaporator Fan Replacement, Remove the fan: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 WRS315SDHW Evaporator Fan Replacement, Remove the fan: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the evaporator fan straight off its motor to remove it.
    • This may require some significant force.
  13. WRS315SDHW Evaporator Fan Replacement, Remove the motor bracket: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 WRS315SDHW Evaporator Fan Replacement, Remove the motor bracket: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 WRS315SDHW Evaporator Fan Replacement, Remove the motor bracket: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your fingers to pry up and release the motor bracket clips from the housing.
  14. WRS315SDHW Evaporator Fan Replacement, Remove the motor bracket: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 WRS315SDHW Evaporator Fan Replacement, Remove the motor bracket: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the motor bracket.
  15. WRS315SDHW Evaporator Fan Replacement, Remove the motor: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 WRS315SDHW Evaporator Fan Replacement, Remove the motor: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 WRS315SDHW Evaporator Fan Replacement, Remove the motor: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the motor straight out of its housing to remove it.
Repair didn’t go as planned? Ask our Answers community for help.
nicO
crwdns2935283:004/14/15crwdne2935283:0
15,927 crwdns2915208:0crwdne2915208:0
crwdns2935297:089crwdne2935297:0
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 176
