WRS315SDHW Drain Pan Replacement
  1. WRS315SDHW Drain Pan Replacement, Safety precautions: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. WRS315SDHW Drain Pan Replacement, Open the doors: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 WRS315SDHW Drain Pan Replacement, Open the doors: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 WRS315SDHW Drain Pan Replacement, Open the doors: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Depending on your repair, open one or both doors.
  3. WRS315SDHW Drain Pan Replacement, Unfasten the front panel: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 WRS315SDHW Drain Pan Replacement, Unfasten the front panel: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 WRS315SDHW Drain Pan Replacement, Unfasten the front panel: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips driver to remove the two 15.2 mm-long screws securing the front panel.
  4. WRS315SDHW Drain Pan Replacement, Remove the front panel: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 WRS315SDHW Drain Pan Replacement, Remove the front panel: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 WRS315SDHW Drain Pan Replacement, Remove the front panel: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the front panel straight off the chassis and remove it.
    • You may have to slightly open the water filter door to remove the front panel completely.
  5. WRS315SDHW Drain Pan Replacement, Unfasten the wiring harness: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 1/4 inch socket wrench to remove the 16.7 mm-long screw securing the wiring harness.
  6. WRS315SDHW Drain Pan Replacement, Reposition the wiring harness: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 WRS315SDHW Drain Pan Replacement, Reposition the wiring harness: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the wiring harness out of its slot in the chassis to access its connectors.
  7. WRS315SDHW Drain Pan Replacement, Disconnect the wiring harness: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 WRS315SDHW Drain Pan Replacement, Disconnect the wiring harness: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 WRS315SDHW Drain Pan Replacement, Disconnect the wiring harness: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the two connectors attached to the door wiring harness.
  8. WRS315SDHW Drain Pan Replacement, Unfasten the rear panel: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 WRS315SDHW Drain Pan Replacement, Unfasten the rear panel: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 WRS315SDHW Drain Pan Replacement, Unfasten the rear panel: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a 1/4 inch socket wrench, or a flathead screwdriver, to remove the seven 16.2 mm-long screws securing the rear panel.
    • Use a 1/4 inch socket wrench to loosen the screw securing the water hose enough for the rear panel to freely move.
  9. WRS315SDHW Drain Pan Replacement, Remove the rear panel: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 WRS315SDHW Drain Pan Replacement, Remove the rear panel: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 WRS315SDHW Drain Pan Replacement, Remove the rear panel: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the rear panel off the chassis to remove it.
  10. WRS315SDHW Drain Pan Replacement, Remove the condenser fan: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 WRS315SDHW Drain Pan Replacement, Remove the condenser fan: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 WRS315SDHW Drain Pan Replacement, Remove the condenser fan: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Put on gloves before continuing, as the sheet metal and the condenser fan itself are sharp.
    • Pull the condenser fan straight off its peg to remove it.
  11. WRS315SDHW Drain Pan Replacement, Unclip the drain pan: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 WRS315SDHW Drain Pan Replacement, Unclip the drain pan: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a flathead screwdriver, or a similar tool, to pry up the metal clip from the back of the drain pan.
  12. WRS315SDHW Drain Pan Replacement, Reposition the wiring harness: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 WRS315SDHW Drain Pan Replacement, Reposition the wiring harness: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 WRS315SDHW Drain Pan Replacement, Reposition the wiring harness: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the wiring harness straight out of the chassis until you can access the drain pan.
  13. WRS315SDHW Drain Pan Replacement, Peel the tape: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 WRS315SDHW Drain Pan Replacement, Peel the tape: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 WRS315SDHW Drain Pan Replacement, Peel the tape: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Peel the tape off the front metal clip attached to the drain pan.
  14. WRS315SDHW Drain Pan Replacement, Unclip the drain pan: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 WRS315SDHW Drain Pan Replacement, Unclip the drain pan: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 WRS315SDHW Drain Pan Replacement, Unclip the drain pan: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your fingers to release the metal clip on the front of the drain pan.
    • Fold the metal clip so that it lays flat on the floor of the chassis.
  15. WRS315SDHW Drain Pan Replacement, Remove the drain pan: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 WRS315SDHW Drain Pan Replacement, Remove the drain pan: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 WRS315SDHW Drain Pan Replacement, Remove the drain pan: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the drain pan toward the front of the chassis to release any remaining clips.
    • Remove the drain pan.
Repair didn’t go as planned? Ask our Answers community for help.
nicO
crwdns2935283:004/14/15crwdne2935283:0
15 945 crwdns2915208:0crwdne2915208:0
crwdns2935297:089crwdne2935297:0
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 188
