WRS315SDHW Dispenser Solenoid Replacement
  1. WRS315SDHW Dispenser Solenoid Replacement, Safety precautions: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. WRS315SDHW Dispenser Solenoid Replacement, Open the doors: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 WRS315SDHW Dispenser Solenoid Replacement, Open the doors: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 WRS315SDHW Dispenser Solenoid Replacement, Open the doors: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Depending on your repair, open one or both doors.
  3. WRS315SDHW Dispenser Solenoid Replacement, Remove the icemaker tray: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 WRS315SDHW Dispenser Solenoid Replacement, Remove the icemaker tray: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the icemaker tray completely out of its slot in the chassis.
  4. WRS315SDHW Dispenser Solenoid Replacement, Unfasten the icemaker assembly: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 WRS315SDHW Dispenser Solenoid Replacement, Unfasten the icemaker assembly: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a 1/4 inch socket wrench to remove the three screws securing the icemaker assembly (shown with the assembly removed):
    • Two 23.9 mm-long screws
    • One 16.7 mm-long screw
  5. WRS315SDHW Dispenser Solenoid Replacement, Reposition the icemaker assembly: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 WRS315SDHW Dispenser Solenoid Replacement, Reposition the icemaker assembly: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 WRS315SDHW Dispenser Solenoid Replacement, Reposition the icemaker assembly: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the icemaker assembly toward the right edge of the refrigerator to release it from its slot in the chassis.
    • Let the icemaker assembly hang to access its connector.
  6. WRS315SDHW Dispenser Solenoid Replacement, Disconnect the icemaker assembly: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 WRS315SDHW Dispenser Solenoid Replacement, Disconnect the icemaker assembly: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 WRS315SDHW Dispenser Solenoid Replacement, Disconnect the icemaker assembly: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the spade connector attached to the icemaker assembly.
  7. WRS315SDHW Dispenser Solenoid Replacement, Remove the icemaker assembly: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the icemaker assembly.
  8. WRS315SDHW Dispenser Solenoid Replacement, Unfasten the icemaker auger assembly: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 1/4 inch socket wrench to remove the four screws securing the icemaker auger assembly:
    • Two 24.1 mm-long screws
    • Two 16.5 mm-long screws
  9. WRS315SDHW Dispenser Solenoid Replacement, Reposition the icemaker auger assembly: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 WRS315SDHW Dispenser Solenoid Replacement, Reposition the icemaker auger assembly: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 WRS315SDHW Dispenser Solenoid Replacement, Reposition the icemaker auger assembly: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the icemaker auger assembly off of its slot in the chassis.
    • Let the assembly hang to access its connector.
  10. WRS315SDHW Dispenser Solenoid Replacement, Disconnect the icemaker auger assembly: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 WRS315SDHW Dispenser Solenoid Replacement, Disconnect the icemaker auger assembly: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 WRS315SDHW Dispenser Solenoid Replacement, Disconnect the icemaker auger assembly: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a flathead screwdriver, or a similar tool, to compress the connector attached to the icemaker auger assembly.
    • Use your hands to disconnect the assembly connector.
  11. WRS315SDHW Dispenser Solenoid Replacement, Remove the icemaker auger assembly: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the icemaker auger assembly.
  12. WRS315SDHW Dispenser Solenoid Replacement, Remove the dispenser: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 WRS315SDHW Dispenser Solenoid Replacement, Remove the dispenser: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 WRS315SDHW Dispenser Solenoid Replacement, Remove the dispenser: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the dispenser head out of its slot in the icemaker auger assembly.
  13. WRS315SDHW Dispenser Solenoid Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 WRS315SDHW Dispenser Solenoid Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the dispenser head out of its metal solenoid cube.
  14. WRS315SDHW Dispenser Solenoid Replacement, Remove the tape: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 WRS315SDHW Dispenser Solenoid Replacement, Remove the tape: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 WRS315SDHW Dispenser Solenoid Replacement, Remove the tape: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Peel the tape off the solenoid connector.
    • Set the tape aside. You'll reuse it during reassembly.
  15. WRS315SDHW Dispenser Solenoid Replacement, Disconnect the solenoid: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 WRS315SDHW Dispenser Solenoid Replacement, Disconnect the solenoid: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 WRS315SDHW Dispenser Solenoid Replacement, Disconnect the solenoid: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the solenoid spade connector straight out of the solenoid to disconnect it.
Repair didn’t go as planned? Ask our Answers community for help.
nicO
crwdns2935283:004/14/15crwdne2935283:0
15 945 crwdns2915208:0crwdne2915208:0
crwdns2935297:089crwdne2935297:0
crwdns2942667:0crwdne2942667:0 167
