crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0WD blue Hard Drivecrwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. WD Blue Hard Drive Teardown, Exterior of Hard drive: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 WD Blue Hard Drive Teardown, Exterior of Hard drive: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 WD Blue Hard Drive Teardown, Exterior of Hard drive: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pre-disassembly
  2. WD Blue Hard Drive Teardown, Remove circuit board: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 WD Blue Hard Drive Teardown, Remove circuit board: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove four screws and circuit board lifts out
  3. WD Blue Hard Drive Teardown, Circuit board interfaces: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Motor contacts
    • Head contacts
  4. WD Blue Hard Drive Teardown, Removing top cover: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 WD Blue Hard Drive Teardown, Removing top cover: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 WD Blue Hard Drive Teardown, Removing top cover: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove 6 perimeter screws
    • Remove screw from under sticker
    • Lift cover off
  5. WD Blue Hard Drive Teardown, Inside details: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 WD Blue Hard Drive Teardown, Inside details: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 WD Blue Hard Drive Teardown, Inside details: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Inside of hard drive
    • Desiccant packet removed from lower right corner
    • Inside of cover
  6. WD Blue Hard Drive Teardown, Head details and dock removal: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 WD Blue Hard Drive Teardown, Head details and dock removal: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 WD Blue Hard Drive Teardown, Head details and dock removal: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Head in dock
    • Head on disk
    • Dock removed
  7. WD Blue Hard Drive Teardown, Head removal p1: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 WD Blue Hard Drive Teardown, Head removal p1: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 WD Blue Hard Drive Teardown, Head removal p1: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Head before bridge removed
    • Remove two screws
    • Lift bridge away
  8. WD Blue Hard Drive Teardown, Head travel limits: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 WD Blue Hard Drive Teardown, Head travel limits: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Stops to limit head travel
    • Red coil over magnet cause the head to rotate
  9. WD Blue Hard Drive Teardown, Head contact removal: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 WD Blue Hard Drive Teardown, Head contact removal: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Contact block installed
    • Remove two screws, contact block is now loose but connected to head by a ribbon cable
  10. WD Blue Hard Drive Teardown, Disk removal p1: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 WD Blue Hard Drive Teardown, Disk removal p1: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 WD Blue Hard Drive Teardown, Disk removal p1: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disk installed
    • Remove 3 screws holding down collar
    • Remove collar
  11. WD Blue Hard Drive Teardown, Disk removal p2: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 WD Blue Hard Drive Teardown, Disk removal p2: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift disk out of case
    • Collar after removal
  12. WD Blue Hard Drive Teardown, Head removal p2: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 WD Blue Hard Drive Teardown, Head removal p2: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 WD Blue Hard Drive Teardown, Head removal p2: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Head installed, simply lift head out of case
    • Remove head
    • Case without head
  13. WD Blue Hard Drive Teardown, Head details: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 WD Blue Hard Drive Teardown, Head details: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 WD Blue Hard Drive Teardown, Head details: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Removed head
    • Contacts for data and head control
    • Head interface to disk
  14. WD Blue Hard Drive Teardown, Empty case: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 WD Blue Hard Drive Teardown, Empty case: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove magnet
    • Remove stop for head on disk
    • Remove head docked stop
  15. WD Blue Hard Drive Teardown, Components laid out: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 WD Blue Hard Drive Teardown, Components laid out: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 WD Blue Hard Drive Teardown, Components laid out: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • All components arranged
Wieli
crwdns2935283:001/08/23crwdne2935283:0
2.141 crwdns2915208:0crwdne2915208:0
crwdns2935297:013crwdne2935297:0
Well done Wieli! Your photographs are very clear and well lighted. Should you decide to edit the guide may I suggest (1) you add what screwdriver tips you used to remove screws and (2) at step 10, highlight the three screws. The screw tips blend in with the collar.
Jim Fogle - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 157
crwdns2942667:0crwdne2942667:0 6,243
