W-King X10 Speaker Replacement
  1. W-King X10 Speaker Replacement, Speaker: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Make sure the X10 is powered off and disconnected from the charger before beginning the replacement.
    • Orient your W-King X10 so that the front is facing you.
    • The W-King logo will be facing you when the X10 is oriented correctly.
  2. W-King X10 Speaker Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 W-King X10 Speaker Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a metal spudger, pry open the top points of the front-facing mesh guard.
    • The connection points are approximately in line with the strap clips on the central control panel.
    • You will hear an audible "pop" when the connection opens, and the top edge of the mesh guard will visibly separate from the X10.
  3. W-King X10 Speaker Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 W-King X10 Speaker Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 W-King X10 Speaker Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lay the X10 on its back so that the bottom is facing you.
    • Using the metal spudger, separate the two connection points located on the left and right sides of the mesh panel as shown.
    • Separate the connection point in the center of the bottom section of the device.
    • As before, all connection points should audibly 'pop' when disconnected, and the mesh panel will visibly separate from the body of the X10.
    • Take care not to accidentally reconnect the points you’ve already separated. Using opening picks to hold the connections open can be helpful as you complete this step.
  4. W-King X10 Speaker Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the front and back mesh panels of the device.
  5. W-King X10 Speaker Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 W-King X10 Speaker Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #2 screwdriver to remove four 15.5 mm screws from the corners of each speaker.
  6. W-King X10 Speaker Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 W-King X10 Speaker Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently pull the speaker straight out of the frame of the device.
    • If you tilt the speaker too far, it may catch on the frame, making it impossible to remove.
    • The speakers are connected to the board by cables, so avoid yanking or pulling on them forcefully.
  7. W-King X10 Speaker Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 W-King X10 Speaker Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a soldering iron to disconnect the three wires connecting the speaker to the motherboard.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Christian Diaz
crwdns2935283:009/12/24crwdne2935283:0
433 crwdns2915208:0crwdne2915208:0
Austin Community College, Team 7-2, Watkins Fall 2024 crwdns2935289:0Austin Community College, Team 7-2, Watkins Fall 2024crwdne2935289:0
AUSTINCC-WATKINS-F24S7G2
crwdns2936751:024crwdne2936751:0 9
crwdns2936753:07crwdne2936753:0 32
crwdns2936753:030crwdne2936753:0 89
crwdns2942667:0crwdne2942667:0 710
