USB port not working anymore? Screen scratched, cracked, or broken? Or is the watch failing to work altogether? This guide can help. Note: This guide requires soldering.
Flip the watch over with the back facing up.
Remove the four 6.0 mm screws on the back plate with the Phillips #00 screwdriver.
Gently pull the back plate from the watch casing.
Lift the master switch from the circuit board.
My smart watch repair
My smart watch repaired
Gently push on the display from the front, near the camera. The circuit board and display will pop out through the back.
Lift the circuit board carefully from the casing, without breaking or detaching the speaker wires at the bottom of the circuit board.
De-solder the black speaker wire from the circuit board.
De-solder the red speaker wire, as in the previous step.
Wait for the solder to cool down and solidify, then remove the circuit board from the casing.
Where can I buy the circuit board ?? Please send me a link or just post it please. Thanks
Where can I buy replacement and how much should it cost?
can you add some infomaton on what kids can do to fix it
Kehinde Abiodun - crwdns2934203:0crwdne2934203:0
