Vtech InnoTab 3S Headphone Port Replacement
  1. Vtech InnoTab 3S Headphone Port Replacement, Rear Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Vtech InnoTab 3S Headphone Port Replacement, Rear Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Vtech InnoTab 3S Headphone Port Replacement, Rear Panel: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • While holding the battery compartment locks down, slide the two battery doors outwards from the sides of the device.
    • Remove the batteries from the device.
  2. Vtech InnoTab 3S Headphone Port Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Vtech InnoTab 3S Headphone Port Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove six 7 mm screws from the interior of the battery compartment using a Phillips #1 screwdriver.
  3. Vtech InnoTab 3S Headphone Port Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Vtech InnoTab 3S Headphone Port Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Vtech InnoTab 3S Headphone Port Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a nylon spudger, remove the five caps that hide the screws.
    • Potential for device damage: Be careful not to scrape the plastic from the device using the spudger.
    • When removing the caps, hold the spudger vertical to the board to make removal easier. Also try to push in with your spudger pointing towards the bottom of the device.
    • Remove the five 5 mm Phillips #1 screws from the rear panel of the device.
  4. Vtech InnoTab 3S Headphone Port Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully remove the rear panel from the front panel of the device.
    • Once the rear panel is removed, you'll be able to see the motherboard and other components within the Vtech InnoTab 3s.
  5. Vtech InnoTab 3S Headphone Port Replacement, Headphone Port: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Vtech InnoTab 3S Headphone Port Replacement, Headphone Port: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Vtech InnoTab 3S Headphone Port Replacement, Headphone Port: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The headphone port is located towards the top left side of the device.
    • With tweezers remove the headphone port from its slot on the device.
    • The headphone port is fastened by two plastic poles. For easier removal lift the headphone port perpendicular to the device upwards.
    • Avoid damaging the plastic poles fastening the headphone port to the device. They are extremely fragile.
    • Desolder the wires securing the headphone port to the device.
    • Be careful when using a soldering iron as it gets extremely hot and will burn.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Karina Garcia
crwdns2935283:008/30/15crwdne2935283:0
878 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 8-2, Eyestone Fall 2015 crwdns2935289:0USF Tampa, Team 8-2, Eyestone Fall 2015crwdne2935289:0
USFT-EYESTONE-F15S8G2
crwdns2942667:0crwdne2942667:0 304
