VTech VM3254 Monitor Circuit Board and Screen Replacement
  1. VTech VM3254 Monitor Circuit Board and Screen Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 VTech VM3254 Monitor Circuit Board and Screen Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn the monitor on its back, and remove the two 8 mm Phillips #0 case screws.
  2. VTech VM3254 Monitor Circuit Board and Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 VTech VM3254 Monitor Circuit Board and Screen Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 VTech VM3254 Monitor Circuit Board and Screen Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the iFixit Jimmy tool to begin removing the face of the monitor.
    • You may need to use an opening pick to hold the screen open as you move the Jimmy tool around all the edges of the device.
    • Once the screen has been separated, lift it from the case.
    • Be gentle while removing the screen. There are wires connected to the two pieces that may be damaged.
  3. VTech VM3254 Monitor Circuit Board and Screen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 VTech VM3254 Monitor Circuit Board and Screen Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four 8 mm Phillips #00 screws from the bracket that secures the battery.
    • Remove the bracket.
  4. VTech VM3254 Monitor Circuit Board and Screen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 VTech VM3254 Monitor Circuit Board and Screen Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 VTech VM3254 Monitor Circuit Board and Screen Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently remove the battery from its location.
    • Carefully disconnect the bundled cable connector from the circuit board.
    Wo finde ich denn genau solch eine Batterie ?
    Besten Gruß
    René
    kroenung1990@googlemail.com
    René Krönung - crwdns2934203:0crwdne2934203:0
  5. VTech VM3254 Monitor Circuit Board and Screen Replacement, Monitor Speaker: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 VTech VM3254 Monitor Circuit Board and Screen Replacement, Monitor Speaker: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 7 mm Phillips #00 screws from the speaker.
    • Carefully remove the speaker and its cords from the motherboard.
    • Handle gently to not break the motherboard or any other parts.
  6. VTech VM3254 Monitor Circuit Board and Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Desolder the wire connecting the speaker to the board.
  7. VTech VM3254 Monitor Circuit Board and Screen Replacement, Monitor Circuit Board and Screen: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 VTech VM3254 Monitor Circuit Board and Screen Replacement, Monitor Circuit Board and Screen: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the three 8 mm Phillips #00 screws.
    • Gently remove the screen and circuit board from the case.
  8. VTech VM3254 Monitor Circuit Board and Screen Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 VTech VM3254 Monitor Circuit Board and Screen Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the button assembly from the front of the screen unit.
    • Flip the screen unit back over and desolder the wire holding it to the case.
Christina Block
crwdns2935283:002/09/23crwdne2935283:0
375 crwdns2915208:0crwdne2915208:0
Utah Tech University, Team 1-2, McMurrin Spring 2023 crwdns2935289:0Utah Tech University, Team 1-2, McMurrin Spring 2023crwdne2935289:0
UTAHTECH-MCMURRIN-S23S1G2
Any source for replacement screens?
Rob Olivieri - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 36
crwdns2942667:0crwdne2942667:0 1,184
