VTech InnoTab 2 Headphone Jack Replacement
  1. VTech InnoTab 2 Headphone Jack Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 VTech InnoTab 2 Headphone Jack Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 VTech InnoTab 2 Headphone Jack Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Apply slight pressure and slide the button above the battery cabinet to the right to open.
    • Remove battery cabinet cover by sliding away from the center of device.
    • This device requires 4AA batteries to function without the AC adaptor.
  2. VTech InnoTab 2 Headphone Jack Replacement, Back Panel: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 VTech InnoTab 2 Headphone Jack Replacement, Back Panel: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 VTech InnoTab 2 Headphone Jack Replacement, Back Panel: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove all nine plastic caps from the back of the device using the plastic opening tool.
    • These covers are made of hard plastic so they may be difficult to remove.
  3. VTech InnoTab 2 Headphone Jack Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 VTech InnoTab 2 Headphone Jack Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 VTech InnoTab 2 Headphone Jack Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the hard rubber tab located by the cartridge slot using the plastic opening tool.
    • Be careful not to apply excessive force.
    • Once the rubber tab is removed unscrew the single 7 mm screw using a J0 screwdriver.
  4. VTech InnoTab 2 Headphone Jack Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 VTech InnoTab 2 Headphone Jack Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove all ten 7mm screws from the back panel of the device using a JO bit screwdriver.
    • Do not use excessive force while removing the screws to prevent damaging the plastic case.
  5. VTech InnoTab 2 Headphone Jack Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 VTech InnoTab 2 Headphone Jack Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the plastic opening tool, detach the back plate from the front piece.
    • Do not use excessive force. If the back plate does not gently come on double check that all screws were removed.
    • Once the back panel is removed, you will be able to see the motherboard and other components within the device.
  6. VTech InnoTab 2 Headphone Jack Replacement, Headphone Jack: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 VTech InnoTab 2 Headphone Jack Replacement, Headphone Jack: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 VTech InnoTab 2 Headphone Jack Replacement, Headphone Jack: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two 7 mm screws from the left bumper of the device using a JO screwdriver.
    • Be careful not to pull to hard when removing the bumper to avoid damage to the circuit.
  7. VTech InnoTab 2 Headphone Jack Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 VTech InnoTab 2 Headphone Jack Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 VTech InnoTab 2 Headphone Jack Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your fingers to gently remove the headphone jack.
    • De-solder the points shown to fully remove the headphone jack from the motherboard.
    • A soldering guide offered by IFIXIT can be found here Soldering Skills
Roberto Valdes
crwdns2935283:010/18/17crwdne2935283:0
302 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S1-G85, Cagle Fall 2017 crwdns2935289:0USF Tampa, Team S1-G85, Cagle Fall 2017crwdne2935289:0
USFT-CAGLE-F17S1G85
crwdns2942667:0crwdne2942667:0 327
