Upgrade iPhone 12 64GB Storage to 256GB
crwdns2936621:0crwdne2936621:0
  1. Upgrade iPhone 12 64GB Storage to 256GB, Upgrade iPhone 12 64GB Storage to 256GB: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Upgrade iPhone 12 64GB Storage to 256GB, Upgrade iPhone 12 64GB Storage to 256GB: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Upgrade iPhone 12 64GB Storage to 256GB, Upgrade iPhone 12 64GB Storage to 256GB: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The capacity of this iPhone is 64GB.
    • Remove the display, Disconnect the battery, and Remove the motherboard.
    How can I get the parts & supplies to actually pull this off?
    Tevin Bennett - crwdns2934203:0crwdne2934203:0
  2. Upgrade iPhone 12 64GB Storage to 256GB: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Upgrade iPhone 12 64GB Storage to 256GB: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Upgrade iPhone 12 64GB Storage to 256GB: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Attach the motherboard to the holder and then attach the high-temperature tape.
    • Heat the side of the NAND with Hot Air Gun at 280℃ and airflow 45.
  3. Upgrade iPhone 12 64GB Storage to 256GB: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Upgrade iPhone 12 64GB Storage to 256GB: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Upgrade iPhone 12 64GB Storage to 256GB: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove black adhesive on the side of the NAND with a Side Glue Cleaner Blade.
    • Heat the NAND with Hot Air Gun at 385℃ and airflow 45. Pry up the NAND with a Pry Knife
    • Apply medium temperature solder paste to the bonding pad with Soldering Iron at 365℃.
  4. Upgrade iPhone 12 64GB Storage to 256GB: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Upgrade iPhone 12 64GB Storage to 256GB: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Upgrade iPhone 12 64GB Storage to 256GB: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Apply a small amount of Paste Flux.
    • Remove tin on the bonding pad with Soldering Iron and Solder Wick.
    • Clean the bonding pad with PCB Cleaner.
  5. Upgrade iPhone 12 64GB Storage to 256GB: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Upgrade iPhone 12 64GB Storage to 256GB: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Upgrade iPhone 12 64GB Storage to 256GB: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Heat the bonding pad with Hot Air Gun at 280℃ to remove the black adhesive.
    • Dip rosin with Soldering Iron and Solder Wick to remove tin on the bonding pad.
    • Clean the bonding pad with PCB Cleaner afterward.
  6. Upgrade iPhone 12 64GB Storage to 256GB: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Upgrade iPhone 12 64GB Storage to 256GB: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Upgrade iPhone 12 64GB Storage to 256GB: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Apply some Paste Flux to the bonding pad and put an iPhone 12 256G NAND in position.
    • Solder the NAND with Hot Air Gun at 365℃ and airflow 45.
  7. Upgrade iPhone 12 64GB Storage to 256GB: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Upgrade iPhone 12 64GB Storage to 256GB: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Upgrade iPhone 12 64GB Storage to 256GB: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Install the motherboard and display. Plug in the data cable and connect the iPhone to the computer. Open 3uTools to flash the iPhone.
    • The phone does not display a progress bar during the flash process and won't display a progress bar until the flash has finished.
    • Activate the phone on 3uTools.
  8. Upgrade iPhone 12 64GB Storage to 256GB: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Upgrade iPhone 12 64GB Storage to 256GB: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Upgrade iPhone 12 64GB Storage to 256GB: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Set up the phone and WiFi can be searched normally.
    • Go to Settings > About. The phone has a 256G capacity.
    • The serial number, WiFi address, and Bluetooth address remain unchanged.
It can be confirmed that the serial number, WiFi address, and Bluetooth address are no longer stored on the NAND. REWA technicians speculate that the serial number, WiFi address, and Bluetooth address are likely stored on EPROM or CPU. The technological change that Apple has made does make storage upgrade easier. But REWA doesn't recommend that users upgrade storage on their own. The first reason is that Apple does not provide a warranty for the phone that has been disassembled before. The second reason is that inappropriate operation may lead to some malfunctions. The water resistance function will be much worse. But for a phone with a bad NAND, it will be much easier to repair.
crwdns2935229:018crwdne2935229:0
REWA
crwdns2935283:011/24/20crwdne2935283:0
17,579 crwdns2915208:0crwdne2915208:0
crwdns2935297:055crwdne2935297:0
crwdns2947412:015crwdne2947412:0
will this work for iphone 12 pro?
Anwesh - crwdns2934203:0crwdne2934203:0
If you have the right flash chip.
Duck -
whats the 256gb NAND ic no
ctrack - crwdns2934203:0crwdne2934203:0
Hi, can you still update it's OS after your upgrade it's memory?
Genzo Shibata - crwdns2934203:0crwdne2934203:0
Yes you can, but doing a NAND upgrade requires basic micro soldering skills and tools, please do not attempt this otherwise, you will fail!
Albert Einstein -
Where did you get the 256GB part from?
LJV - crwdns2934203:0crwdne2934203:0
you can probably get one from a phone, the same model but just more storage
School User 1 -
How much for you to do this to me I have an old iPhone I had upgraded to 128 gb for 900 but it broke and I got an iPhone 12 with 64 Gb for 200
How much to sen you both phone so that you can upgrade for me
Garcia K - crwdns2934203:0crwdne2934203:0
what is an over all estimate to fix screen(replace-corner is black) and to flow a new memory chip?
Ricky Sanchez - crwdns2934203:0crwdne2934203:0
Just like that it can be done or you need to copy some data from old storage?
And can it be upgraded to 512gb or 1tb
Eric 21 - crwdns2934203:0crwdne2934203:0
So simple,
Can you upgrade iphont 12 to 1 tb or 512gb
is REWA available in India ? Will you do it for others iPhone.
Alfacharli - crwdns2934203:0crwdne2934203:0
I have iPhone 12 mini with 64gb I wanna make it 512gb and is it possible and how much will it cost
Rithik Nair - crwdns2934203:0crwdne2934203:0
I only see a 256 GB NAND for an iPhone 12 mini. It will be about 60 euros when you do it yourself. If you have any questions about the process, feel free to ask.
Florian Westermeyer -
crwdns2936751:024crwdne2936751:0 34
crwdns2936753:07crwdne2936753:0 250
crwdns2936753:030crwdne2936753:0 1,371
crwdns2942667:0crwdne2942667:0 53,770
