Uniden Dect 6.0 Keyboard Replacement
  1. Uniden Dect 6.0 Keyboard Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the battery compartment on the back of the Uniden home phone.
    • Place your finger on the groove, and pull directly back on the cover to access to the battery.
    the hand set does not work nither one will charge I just bought it from Walmart in sant cloud florida I have the uniden 6.0 answering mic plus the 2 hand sets 1 for the base and 1 for the ex phone what do I do because I had it on charge for 2 days now.i m disabled and need I phone to work thank you for any help u can give me or please send me 2 batterys 1 for each phone and I will send the 2 I just got with my new phone hope that works after I replace the batterys ty u can send to 1311 w rosewood ave sant cloud florida 34771 thank you
    star - crwdns2934203:0crwdne2934203:0
    It is very difficult to open the battery compartment.
    Thomas Alessi - crwdns2934203:0crwdne2934203:0
    Does it slide down or open out from where the finger groove is?
    I can’t get it off.
    K scott - crwdns2934203:0crwdne2934203:0
    I had the same problem removing the back. I placed a knife in the center and was finally able to get it off. I think the red & black wire on the battery causes the problem.
    Tanya Brown - crwdns2934203:0crwdne2934203:0
    I tried knife, but I can't get battery cover off of one of the Uniden phones. I have new batteries but can't get the blasted cover off.
    Carolyn B - crwdns2934203:0crwdne2934203:0
  2. Uniden Dect 6.0 Keyboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the white battery pack from the battery compartment.
  3. Uniden Dect 6.0 Keyboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the red-and-black-wired port from the plug directly under the battery compartment.
  4. Uniden Dect 6.0 Keyboard Replacement, Keyboard: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Uniden Dect 6.0 Keyboard Replacement, Keyboard: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a Phillips #1 screwdriver, remove the two .9 mm screws on the back of the device on each side of the battery pack.
  5. Uniden Dect 6.0 Keyboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using your fingers, gently lift and separate the front of the housing from the back housing.
    • Potential for device damage: While separating the back housing from the front, be sure to open from the sides as pictured.
  6. Uniden Dect 6.0 Keyboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently remove the loose keyboard from the lined gel casing located under the front housing of the front of the phone.
Megan Lawrence
crwdns2935283:001/14/15crwdne2935283:0
534 crwdns2915208:0crwdne2915208:0
USF Sarasota-Manatee, Team 1-3, Stewart Winter 2015 crwdns2935289:0USF Sarasota-Manatee, Team 1-3, Stewart Winter 2015crwdne2935289:0
USFSM-STEWART-W15S1G3
crwdns2935297:018crwdne2935297:0
Great to have this guide! I’d add that (at least on my aging handset). Prying it open can feel a bit sketchy cause it may resist a bit, so I used the metal spudger to go around the edge lifting the tabs. But the plastic on these is pretty great and will not break even puting some force on it.
Also be mindful of the speaker on the back which is connected to the front case.
Ivan Viales - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 3,499
