UnBranded UB-15MS10 Back Panel Replacement
  1. UnBranded UB-15MS10 Back Panel Replacement, Back Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the cover over the Micro SD outlet by using a plastic opening tool to pry open and push out the cover panel.
  2. UnBranded UB-15MS10 Back Panel Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 4-mm #0 screws from the inside of the Micro SD compartment.
  3. UnBranded UB-15MS10 Back Panel Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 UnBranded UB-15MS10 Back Panel Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert blue guitar picks in the crease between the top and bottom panels starting on the same end as the Micro SD slot.
    • Inserting the picks directly under the Micro SD compartment was the easiest place to get started. It still requires some force.
  4. UnBranded UB-15MS10 Back Panel Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert the black spudger between the guitar picks in order to pry open gaps between the blue guitar picks.
    • As the gaps open, slide the guitar picks along the sides to separate the panels.
    Some close up shots of the seam that you're making sure not to miss internal tabs that hold the back on.
    Jorge Murphy - crwdns2934203:0crwdne2934203:0
  5. UnBranded UB-15MS10 Back Panel Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry all four sides apart using the blue guitar picks and the black spudger until they can easily be pried apart by hand.
    Would love to see more photos on every single location of the snap tabs under the back cover. I don't want to snap any of the tabs off by pulling to hard around these snap tabs.
    What is mean when you say by hand? "until they can easily be pried apart by hand." Using your fingers or a tool?
    David Gilleran - crwdns2934203:0crwdne2934203:0
crwdns2935229:08crwdne2935229:0
Andrea Hammans
crwdns2935283:009/16/15crwdne2935283:0
579 crwdns2915208:0crwdne2915208:0
IUPUI, Team 2-1, Baechle Fall 2015 crwdns2935289:0IUPUI, Team 2-1, Baechle Fall 2015crwdne2935289:0
IUPUI-BAECHLE-F15S2G1
Thanks you, work good for me.
Cesar Alvarez - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 1,347
