A common issue with smart devices is a faulty battery. This guide goes through the steps needed to replace the battery of a Trio Stealth-Mini.
Locate the indentation at the bottom of the device.
Pull on the indentation and take off the casing of the device.
Remove the faulty battery and insert a replacement in its slot.
Where can I get a battery for this device
