Trackpad Prereq
crwdns2862623:0crwdne2862623:0
crwdns2942641:0crwdne2942641:0
  1. Trackpad Prereq, Remove trackpad cable connector bracket: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Trackpad Prereq, Remove trackpad cable connector bracket: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a T3 Torx driver to remove the two 1.8 mm screws securing the cover bracket for the keyboard and trackpad cable connectors.
    • Remove the bracket.
  2. Trackpad Prereq, Disconnect trackpad cable: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Trackpad Prereq, Disconnect trackpad cable: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to disconnect the trackpad cable by prying its connector straight up from the logic board.
  3. Trackpad Prereq: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply mild heat to the trackpad ribbon cable to soften the adhesive securing it to the battery.
    • You can use an iOpener, hair dryer, or heat gun, but be careful not to overheat the battery. The cable should be warm, but not too hot to touch.
  4. Trackpad Prereq: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Trackpad Prereq: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Trackpad Prereq: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully peel the trackpad cable up off the battery, and push it out of the way.
    • Don't crease or tear the cable. If you have trouble, don't force it—apply more heat and try again.
  5. Trackpad Prereq, Remove the trackpad assembly screws: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Trackpad Prereq, Remove the trackpad assembly screws: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a T5 Torx driver to remove the 13 screws securing the trackpad assembly:
    • Nine 5.8 mm screws
    • Four 4.9 mm screws
    • These screws all look similar—be careful not to mix them up.
    • Adding a little blue threadlocker to the screw threads during reassembly can help prevent the screws from working themselves loose over time.
    • Install the screws loosely at first, and then check the trackpad alignment before tightening them down.
  6. Trackpad Prereq, Remove the trackpad: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Trackpad Prereq, Remove the trackpad: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Trackpad Prereq, Remove the trackpad: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Swing the display open slightly, but keep the MacBook upside-down. The trackpad assembly should separate and lay flat on the display.
    • Carefully feed the trackpad's ribbon cable through its slot in the chassis.
  7. Trackpad Prereq: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Trackpad Prereq: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Trackpad Prereq: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • As you remove the trackpad assembly, be very careful not to lose the nine small metal washers resting on the screw posts. (They will fly off and get lost with very little provocation.)
    • Remove the trackpad assembly.
Carsten Frauenheim
138 524 crwdns2915208:0crwdne2915208:0
crwdns2935297:0379crwdne2935297:0
Staff
crwdns2935297:019 823crwdne2935297:0
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 37
