Toshiba Satellite L775D-S7340 Keyboard Replacement
  1. Toshiba Satellite L775D-S7340 Keyboard Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Make sure the laptop is unplugged and powered off.
    • Locate the battery latches on the underside of the laptop.
  2. Toshiba Satellite L775D-S7340 Keyboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the right latch to the right until you hear it lock into place.
    • Slide the left latch to the left and hold it.
  3. Toshiba Satellite L775D-S7340 Keyboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the battery out towards you.
  4. Toshiba Satellite L775D-S7340 Keyboard Replacement, Keyboard: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry up the thin narrow strip of facing above the keyboard using the opening tool.
  5. Toshiba Satellite L775D-S7340 Keyboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four screws securing the keyboard using the T4 Torx screwdriver,
    These screws are Phillips, not Torx T4.
    John Beekman - crwdns2934203:0crwdne2934203:0
  6. Toshiba Satellite L775D-S7340 Keyboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite L775D-S7340 Keyboard Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the keyboard slowly using the opening tool and lean it toward touchpad.
    • It will still be held by the connector ribbon. Make sure not to pull out the connector ribbon.
  7. Toshiba Satellite L775D-S7340 Keyboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The ribbon is attached by a white clip. Wedge the white clip up carefully using the spudger. This will release the connector ribbon and you can now remove the keyboard.
    Damaged white locking clip
    cyn lan - crwdns2934203:0crwdne2934203:0
Madeline Park
crwdns2935283:009/21/17crwdne2935283:0
441 crwdns2915208:0crwdne2915208:0
Washington State, Team S4-G120, Phelps-Hillen Fall 2017 crwdns2935289:0Washington State, Team S4-G120, Phelps-Hillen Fall 2017crwdne2935289:0
WSU-PHELPS-HILLEN-F17S4G120
crwdns2931471:06crwdne2931471:0
I need to know how to change a plasma for a Toshiba Satellite L775D-S7340
Cyndi May Evans - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 1,817
