Toshiba Satellite L655D-S5095 RAM Replacement
  1. Toshiba Satellite L655D-S5095 RAM Replacement, RAM: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite L655D-S5095 RAM Replacement, RAM: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the three 4.6 mm screws holding the panel using a #1 size Phillips head screwdriver. The panel is centered on the bottom of the laptop.
  2. Toshiba Satellite L655D-S5095 RAM Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the cover, firmly lifting from the indent. It is recommended that you leave the screws in the panel.
  3. Toshiba Satellite L655D-S5095 RAM Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toshiba Satellite L655D-S5095 RAM Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toshiba Satellite L655D-S5095 RAM Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Push the two tabs outwards, away from the RAM. The RAM should spring up.
  4. Toshiba Satellite L655D-S5095 RAM Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toshiba Satellite L655D-S5095 RAM Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toshiba Satellite L655D-S5095 RAM Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the top RAM stick out gently.
    • Repeat steps 3 and 4 for the bottom RAM stick.
    • When installing the new RAM, line up the notches in the RAM's contacts and insert it at the same angle you removed it.
crwdns2935229:08crwdne2935229:0
Jerry Wakai
crwdns2935283:001/31/13crwdne2935283:0
377 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 7-7, Maness Winter 2013 crwdns2935289:0Cal Poly, Team 7-7, Maness Winter 2013crwdne2935289:0
CPSU-MANESS-W13S7G7
Awesome & Simple! Thank-you! My Model is a Satellite P105-S6147 1GBX2 DDR2-666 Sodimm 2BG Total.
Sandra Crockett - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 3,771
