Toshiba Satellite L55-A CMOS Battery Replacement
  1. Toshiba Satellite L55-A CMOS Battery Replacement, Remove the RAM cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Before you begin, be sure to power down your laptop.
    • Flip the laptop over so that the back cover is facing up.
    • Unscrew the captive Phillips screw securing the RAM cover.
  2. Toshiba Satellite L55-A CMOS Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite L55-A CMOS Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift up the edge of the RAM cover and remove it.
  3. Toshiba Satellite L55-A CMOS Battery Replacement, Disconnect the ethernet connector cable: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toshiba Satellite L55-A CMOS Battery Replacement, Disconnect the ethernet connector cable: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toshiba Satellite L55-A CMOS Battery Replacement, Disconnect the ethernet connector cable: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use an opening tool to pry up the ethernet connector cable from its socket near the RAM module.
    • Disconnect the cable.
    • During reassembly, make sure you re-insert this connector right-side-up. The connector is keyed to plug in only one orientation, so if it doesn't slide into place easily, turn it around and try the other way.
  4. Toshiba Satellite L55-A CMOS Battery Replacement, Remove the back cover: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the thirteen 6.8 mm long Phillips screws securing the back cover.
  5. Toshiba Satellite L55-A CMOS Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toshiba Satellite L55-A CMOS Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toshiba Satellite L55-A CMOS Battery Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the point of an opening pick in the seam between the SuperMultiDrive and the rest of the back cover.
    • Push the SuperMultiDrive's lip away from the back cover to disconnect the drive.
    • Slide the drive out of the bay and remove it from the laptop.
  6. Toshiba Satellite L55-A CMOS Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite L55-A CMOS Battery Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The back cover is still held in place by plastic clips.
    • Insert the point of an opening pick into the back cover seam near the ethernet port.
    • Twist the pick to release the plastic clips along the edge.
  7. Toshiba Satellite L55-A CMOS Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toshiba Satellite L55-A CMOS Battery Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toshiba Satellite L55-A CMOS Battery Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grasp the loosened back case edge with your hand and lift it slowly away from the laptop. The remaining clips should release with ease.
    • If you meet significant resistance, stop and check for forgotten screws.
    • Remove the back cover.
    • To reinstall the back cover, align the cover and press along the edges to snap the clips back in place.
  8. Toshiba Satellite L55-A CMOS Battery Replacement, Remove the coin cell: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toshiba Satellite L55-A CMOS Battery Replacement, Remove the coin cell: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toshiba Satellite L55-A CMOS Battery Replacement, Remove the coin cell: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your fingernail or an opening pick to push the gold metal clip off of the top of the coin cell.
    • Pry the coin cell out of its holder and remove it.
    • To install a replacement battery, align the battery and press it firmly into the holder until the battery snaps into position.
Arthur Shi
crwdns2935283:001/03/18crwdne2935283:0
298 862 crwdns2915208:0crwdne2915208:0
crwdns2935297:0684crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021 981crwdne2935297:0
crwdns2942667:0crwdne2942667:0 2,855
