Toshiba Satellite E45-B4100 Battery Replacement Replacement
  1. Toshiba Satellite E45-B4100 Battery Replacement Replacement, Battery Replacement: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the fourteen 3.75mm screws with a Phillips #0 Screwdriver as shown.
  2. Toshiba Satellite E45-B4100 Battery Replacement Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pull out the battery.
Tori Ryals
crwdns2935283:010/11/16crwdne2935283:0
41 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 1-4, Leahy Fall 2016 crwdns2935289:0USF Tampa, Team 1-4, Leahy Fall 2016crwdne2935289:0
USFT-LEAHY-F16S1G4
You don't need to remove all the screws - only the two that are directly above the battery compartment. Tried it myself!
Patrick Lenny - crwdns2934203:0crwdne2934203:0
Tengo una duda, es unicamente esta bateria la que hay que reemplazar o existe alguna bateria interna que tambien se daba reemplazar?
Nicolas del Castillo - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 2,019
