Toshiba Satellite C660 CMOS / BIOS Battery Replacement
crwdns2936621:0crwdne2936621:0
  1. Toshiba Satellite C660 CMOS / BIOS Battery Replacement, CMOS / BIOS Battery replacement: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite C660 CMOS / BIOS Battery Replacement, CMOS / BIOS Battery replacement: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the charger and the battery.
  2. Toshiba Satellite C660 CMOS / BIOS Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toshiba Satellite C660 CMOS / BIOS Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toshiba Satellite C660 CMOS / BIOS Battery Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remov the narrow plastic lid and unscrew 4x Phillips screw.
  3. Toshiba Satellite C660 CMOS / BIOS Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toshiba Satellite C660 CMOS / BIOS Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toshiba Satellite C660 CMOS / BIOS Battery Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the keyboard.
  4. Toshiba Satellite C660 CMOS / BIOS Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toshiba Satellite C660 CMOS / BIOS Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toshiba Satellite C660 CMOS / BIOS Battery Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • This is the internal CMOS / BIOS battery. Use small screwdriver to remove it.
  5. Toshiba Satellite C660 CMOS / BIOS Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • And that's it!
    Sur mon satellite L555-135, ce n’est pas une CR32, mais une petite pile soudée. Est-elle compatible avec une CR32 ? Il n’y a aucune inscription sur la pile. Merci.
    Pat Bazar - crwdns2934203:0crwdne2934203:0
    Oui c'est compatible car les bios nécessitent 3 volts pour rester à jour. Vous pouvez très bien utiliser une pile de 3v plus petite mais elle se déchargera plus rapidement ou plus grosse (mais toujours en 3v) pour peut qu'elle rentre dans l'emplacement prévu par le constructeur.
    Les CR32 sont devenus des standards.
    Hyperion - crwdns2934203:0crwdne2934203:0
    Ni siquiera publicaste el tipo de pila que necesitas para recambio, solo las herramientas.
    Bastante inútil
    Marcus Bingham - crwdns2934203:0crwdne2934203:0
crwdns2935229:016crwdne2935229:0
ZFix
crwdns2935283:012/09/13crwdne2935283:0
194,787 crwdns2915208:0crwdne2915208:0
crwdns2935297:0330crwdne2935297:0
Master Techs crwdns2935289:0Master Techscrwdne2935289:0
Community
crwdns2931471:0327crwdne2931471:0
crwdns2935297:01,422crwdne2935297:0
The receptacle that the battery goes into is loose and not making contact on the (+) terminal. This is a shoddy design. You can test it by pressing the receptacle down and powering the laptop. Works fine. You cannot solder the terminal for fear of upsetting the motherboard. Any solutions.
Until I find one, I continue to press F1, go to Control Panel and set the time and date every time I power on the laptop.
Hari Razdan - crwdns2934203:0crwdne2934203:0
same battery CR2032 for Toshiba sattelite L775 G10 ?
thx
gagalot Eric - crwdns2934203:0crwdne2934203:0
Bonjour,
Je ne savais pas où était cette pile dans un Toshiba 650D, et j'hésitais à me lancer dans le démontage de ce portable. J'ai trouvé ce tutoriel qui explique parfaitement la marche à suivre, et j'ai réussi à changer cette pile en deux temps trois mouvements!!
Un grand merci donc.
PS: je n'ai pas débranché le connecteur clavier et n'ai pas eu de problème.
Jean-Marc GERMAIN - crwdns2934203:0crwdne2934203:0
Bonjour, très explicite sauf pour débrancher le clavier, j'ai pas insisté de peur de faire de la casse
ombre - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 52
crwdns2936753:030crwdne2936753:0 189
crwdns2942667:0crwdne2942667:0 51,354
