Toshiba Satellite A105-S4284 RAM Replacement
  1. Toshiba Satellite A105-S4284 RAM Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite A105-S4284 RAM Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Make sure your computer is turned off and the computer is not plugged in.
    • Turn your laptop upside down, and slide the right release tab outward.
    • Using you left hand, hold the left release tab towards the left side and then pull the battery out.
  2. Toshiba Satellite A105-S4284 RAM Replacement, RAM: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite A105-S4284 RAM Replacement, RAM: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Loosen the screw located on the cover of the RAM using Phillips #1 screwdriver.
    • You will not be able to remove the screw from the panel as it is designed to stay in the panel.
  3. Toshiba Satellite A105-S4284 RAM Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite A105-S4284 RAM Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With your fingers, carefully remove the middle panel by lifting the edge with the indent.
  4. Toshiba Satellite A105-S4284 RAM Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toshiba Satellite A105-S4284 RAM Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toshiba Satellite A105-S4284 RAM Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using your fingers, release the tabs on both ends of the RAM.
    • Pull the RAM out.
    • The other RAM is released in the same manner.
pfedigan
crwdns2935283:004/12/13crwdne2935283:0
11 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 2-23, Maness Spring 2013 crwdns2935289:0Cal Poly, Team 2-23, Maness Spring 2013crwdne2935289:0
CPSU-MANESS-S13S2G23
crwdns2935297:013crwdne2935297:0
how to remove a bios passcode off of a Toshiba Satellite a105 s4374 laptop
simeon cole - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 2,199
