This guide will teach you how to replace the battery of the Toshiba Portege Z835-P330.
Remove the thirteen 1.4mm screws on back of device using a Phillips #2 screwdriver.
Locate hidden screw found in the middle of back hardcover.
Remove the single Torx Security screw using a TR7 screwdriver.
Peel off hardcover to expose interior of device.
Remove the six 1 mm screws using a Phillips #1 screwdriver.
Remove the white plug connected to the battery by gently pulling it out of the socket.
Lift battery up by its sides, and it should easily come off.
These steps also work for the Z935-P300. NOTE: the center screw in step two is a Torx Security TR7.
Will it lose it’s memory when the power and battery are disconnected? Do I need to back it up before I do this? My battery is so dead that the laptop shuts down after just a few minutes without the ac cord plugged in.
Thank you!
I suspect you have already completed your repair and now know the answer, however, in the event that you are still waiting on a response. The short answer is no, the storage drive will not loose data when changing the battery. Despite this, it is always wise to have a backup.
Could anyone please tell me which type of screws are these ?
Which screws are you referring to? I believe they all have their details size and type listed above. Is there one in particular you need further detail on?
trying to find a CMOS RTC Battery for Toshiba z830 p370, so many options but I don’t know which one is the proper one, I will appreciate any help
