Thustmaster Ferrari 458 Spider Racing Wheel motherboard Replacement
  1. Thustmaster Ferrari 458 Spider Racing Wheel motherboard  Replacement, Bottom Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the black 10mm using a JIS #1 screw driver.
    • There are 12 screws.
    • Two of the screws are deep inside the device you might need to use a slim screwdriver.
    • In the picture you see a plastic opening tool instead of screw driver because we did not have our screw driver when we were taking the picture.
  2. Thustmaster Ferrari 458 Spider Racing Wheel motherboard  Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Thustmaster Ferrari 458 Spider Racing Wheel motherboard  Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 10mm black screws on the top of device using a Hex 2.5mm Key. Only the two outside screws.
    • Gently pull apart both halves of device to access inside.
    Does anyone know what of rotary encoder sits here or other thrustmastrer wheel?
    Jakub - crwdns2934203:0crwdne2934203:0
  3. Thustmaster Ferrari 458 Spider Racing Wheel motherboard  Replacement, Motherboard: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a small plastic opening tool, gently pry up the white connector that connects the USB cable to the board.
    • Cut the black cable as close to the board as possible.
    • Remove the three screws using PH2 screw driver.
    where can I buy the motherboard for the ferrati 458 xbox one x steering wheel
    Antoci Stefan Stefan - crwdns2934203:0crwdne2934203:0
    I have the same steering wheel but the cable is cut and I can't change it
Mohammed Alsogair
crwdns2935283:010/18/17crwdne2935283:0
369 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S1-G33, Cagle Fall 2017 crwdns2935289:0USF Tampa, Team S1-G33, Cagle Fall 2017crwdne2935289:0
USFT-CAGLE-F17S1G33
how can I replace elastic cord?
geoff - crwdns2934203:0crwdne2934203:0
Just so every one knows its easier then changing a baby's arse for the first ten times if any one hasn’t yet I'm not gunna paint a picture I'm just going to sit here and smile. But as I was saying I found what was wrong just got to get my parts and fit as easy as that and if you don't know or butter for fingers then just let some other capable suspect do it, Save money.
scott_vernon85 - crwdns2934203:0crwdne2934203:0
Where did you get a replacement motherboard?
Paul Stewart - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 5,856
