Thustmaster Ferrari 458 Spider Racing Wheel USB Cable Replacement
  1. Thustmaster Ferrari 458 Spider Racing Wheel USB Cable Replacement, Bottom Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the black 10mm using a JIS #1 screw driver.
    • There are 12 screws.
    • Two of the screws are deep inside the device you might need to use a slim screwdriver.
    • In the picture you see a plastic opening tool instead of screw driver because we did not have our screw driver when we were taking the picture.
  2. Thustmaster Ferrari 458 Spider Racing Wheel USB Cable Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Thustmaster Ferrari 458 Spider Racing Wheel USB Cable Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 10mm black screws on the top of device using a Hex 2.5mm Key. Only the two outside screws.
    • Gently pull apart both halves of device to access inside.
    Does anyone know what of rotary encoder sits here or other thrustmastrer wheel?
    Jakub - crwdns2934203:0crwdne2934203:0
  3. Thustmaster Ferrari 458 Spider Racing Wheel USB Cable Replacement, USB Cable Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Thustmaster Ferrari 458 Spider Racing Wheel USB Cable Replacement, USB Cable Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a small plastic opening tool, gently pry up the white connector that connects the USB cable to the board.
  4. Thustmaster Ferrari 458 Spider Racing Wheel USB Cable Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Thustmaster Ferrari 458 Spider Racing Wheel USB Cable Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Desolder the black cable that connects the USB port to the motherboard.
    • For more information on how to solder and desolder connections, please visit this guide.
Mario Nunez
crwdns2935283:010/18/17crwdne2935283:0
439 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S1-G33, Cagle Fall 2017 crwdns2935289:0USF Tampa, Team S1-G33, Cagle Fall 2017crwdne2935289:0
USFT-CAGLE-F17S1G33
crwdns2947412:07crwdne2947412:0
kunt u mij vertellen waar ik het kabeltje kan kopen?
Rene
Rene Haeren - crwdns2934203:0crwdne2934203:0
Can you advise on where to obtain a new usb cable please? (clentonmalcolm@gmail.com)
Malcolm Clenton - crwdns2934203:0crwdne2934203:0
Have you solved it? I'm worried it's different from the regular usb line.
sunned -
Then wat where do u get usb cord to replace it some one plz explian
lilybaxter505 - crwdns2934203:0crwdne2934203:0
Oh man.. the first comment about this was 2019 and we both are still waiting for an answer huh
Hez van der Meij -
Where can I find a replacement USB cable for the Thrustmaster 458?? The one that goes from the xbox to the thrustmaster controller. Thank you.
freak4yahweh - crwdns2934203:0crwdne2934203:0
About the usb cable. Look for a "5 pin Xbox 360 usb cable". The black pin farthest from the soldered wire is a shield ground wire. Just splice that right most black wire with the soldered black wire to ground the board and cable. These 2 black wires on the board are the furthest points away from each other. I found this out by carefully trimming the sheath from around the wires and sliding the shielding towards the remaining cable
Daniel Gomez - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 33
crwdns2942667:0crwdne2942667:0 9,669
