Use this guide to replace broken gas or break pedal.
Start by removing both pedals. Remove the two black 20mm screws on each pedal using a PH2 Phillips head screw driver.
Remove the 10mm long black screws on the back of the base using a PH2 Phillips head screw driver. There are 13 screws total.
Gently lift cover out to access inside.
Does the adapter come with the pedals.
Does the adapter come with the thrustmaster pedals
Push the pin that holds the pedal out from middle outward.
I’m in need of the rotary switch # B25k45 you see in your pic that controls the speed, I’m having trouble finding them and can’t race till I do, Please help drmwevr1970@gmail
Install the new pedal with springs and pin and make sure that the pin holds them together.
Add a little grease on pin when installing the new pedal.
Repeat steps in reverse to reassemble device.
crwdns2947412:07crwdne2947412:0
Hi, where can you get replacement springs? Cannot find anything online that sells this specific diameter and angle at both ends? Can I contact Thrustmaster to get more springs or a replacement pedal set?
I am also looking for this spring. Any help would be appreciated.
thanks
Me too. Are these springs available?
I only need 1 spring, not 10....
Anyone selling 1 spring?
help i cant put it back together
hey i did a different repair but followed these steps to open it. only problem is that i cant get the cover back on the main body of it
I need help when I connect the pedals accelerate alone and brake alone
Anthony - crwdns2934203:0crwdne2934203:0
